Replace fan clutch or go electric - Defender Source
Old July 16th, 2015, 04:43 PM
gilby's Avatar
gilby
1994 Defender 90
Question for the masses.
94 ST overheating with bad fan clutch (many thanks to previous threads from the forum for helping with diagnosis!).
Replace clutch and keep engine driven fan, or go electric?
I live in the south and find myself at traffic lights in 90-degree heat.
Ready...GO
Old July 16th, 2015, 04:49 PM
2 speed electric Ford Taurus fan. That's how I roll and very few people on the board deal with more heat than I do.
Old July 16th, 2015, 04:52 PM
BostonAndy's Avatar
BostonAndy
Andrew
Moose :: 1985 110
viscus for me. original and less wiring to troubleshoot.
Old July 16th, 2015, 04:53 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Just replace the clutch. I had electric and went back to the mechanical after they started acting up.
Jimmy Buffett
Old July 16th, 2015, 05:00 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Viscous!
And a 36mm slim spanner to get the fan in or out.
While driving with the R380 I normaly had the fan out.
Only during summertime and carrying my Sankey the fan was inside.
With the auto box I guess it's better to have a fan inside?
Old July 16th, 2015, 05:01 PM
gilby's Avatar
gilby
1994 Defender 90
Conflicted between keeping original for original's sake, or going with better stop-and-go cooling in the summer
Old July 16th, 2015, 05:27 PM
I thought they don't fit on a V8??
Old July 16th, 2015, 05:28 PM
Electric is fine, but it is down to the quality of the installation, control system and wiring. If you do it to an OEM level, it will be as reliable as a viscous setup, if not more.
Old July 16th, 2015, 05:40 PM
I ran a Flex-Fan with my V8. The Taurus fan is on my diesel but I think it would work if you trimmed up the cowling that comes as part of the fan. It does move a ton of air and yes, the quality of the install will obviously dictate the reliability.
Old July 16th, 2015, 05:48 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
FWiw I have 145k miles on a total of 2 viscous fans. No brainer. Stop/go traffic is not an issue if all the other related components are also up to spec and proper maintenance is followed on a regular basis. An electric fan is not going to over compensate for other weak links and lack of proper maintenance.
Old July 16th, 2015, 05:51 PM
Roverdoc's Avatar
Roverdoc
Dan Kemper
1997 D90 SW #278
I vote for replacing with factory viscous and fan. When all components are working it should keep the rover plenty cool. Minor changes like HD viscous, RRC fan (larger) or more cores in the radiator is all you should need. If temps creeping during traffic in may be an indicator that more than just the viscous needs attention. HG? radiator? etc
Old July 16th, 2015, 05:56 PM
rovertrader's Avatar
rovertrader
Dale
Running a spiced 4.6, and had slight heat issues. Spoke to Allisport and even they recommend keeping viscous over electric. The biggest advantage to electric is being able to turn off during water crossings. I stayed viscous (new one installed) and went to a new 3.5 radiator with an external oil cooler, and issue solved. My next step was an Allisport rad, or a Davis rad, but so far so good with near record highs x 2 months- mid 90's everyday!
Old July 16th, 2015, 06:15 PM
Departing90
Sasha
95 D90
The best setup by a clear mile is the factory fan clutch with a pusher electric fan behind the grill. best of both worlds with built in back-up! The fan clutch is easy to diagnose and fix in a pinch when in the field. With a failed fan clutch you simply put a screw through the mechanism thereby locking it up!
Old July 16th, 2015, 06:19 PM
gilby's Avatar
gilby
1994 Defender 90
Thanks all!
Newer radiator, lines good, pump good, no coolant loss, pressure tested. Clutch loose.
Any cons to electric, other than being isolated and having electrical fan failure?
Any specific pro's out there?
Thanks from a newbie
Old July 16th, 2015, 06:21 PM
Interesting they favor Viscous over electric especially since they sell a V8 radiator with dual electric
Land Rover Defender V8 Direct Replacement Alloy Radiator with Spal fans cowl - AlliSport
Old July 16th, 2015, 06:52 PM
gilby's Avatar
gilby
1994 Defender 90
Appreciate everyone's responses.
Interested in hearing more opinions as well to get a consensus.
Old July 16th, 2015, 09:42 PM
rovertrader
Dale
Fully aware, and I was a bit surprised- but according to them the vicious provides more air flow, and they suggested keeping it as such. Here are their words exactly:
Hi Dale,
The viscous fan will have more cooling capacity than the electrics, and I know this radiator will have sufficient capability for your job. If you had overheating issues with this rad, something else is at fault!
I would also recommend an external oil cooler for max efficiency.
The down side is our current lead time is quite long I'm afraid, possibly around 6 weeks- ish.
If you wanted to make an order, I can take all your details and let me know how you want to make payment. Then I can let you know when the part is in progress.
I hope this helps!
Best regards,
Andrew
Old July 17th, 2015, 06:49 AM
viscous fan clutch vote.
Old July 17th, 2015, 06:57 AM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Viscous vote.
When it comes to engine stuff, it's all oem for me, right down to the spark plugs.
Old July 17th, 2015, 10:33 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
I have a Range-Rover p38 air con radiator twin fan. Anyone ever tried this? (For a 200tdi). It seems to be the proper size but, will it push/pull enough air?
Sorry for hijacking but since the p38 are in the scrap yard now a day, might be as cheap as a taurus fan. Since it's a twin fan setup, might be able to have one fan going and the other stop. Have them both running in hard working condition.. At the moment, no fan and it doesn't go higher then normal..
Injector Replace / Rebuild / Nozzle Replace icnsltmfg Defender Technical Discussions 8 April 29th, 2015 08:29 PM
SPAL 11" Electric Fan and X-Eng X-Fan Kit crown14 For Sale - Parts 2 February 5th, 2010 01:12 PM
Visc. Clutch vs Electric Fan snurp Defender Technical Discussions 27 June 5th, 2008 12:55 PM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 06:19 AM
D90 -- Fan clutch and fan Vadim Wanted 3 August 1st, 2004 01:00 PM
