Replace fan clutch or go electric - Page 2 - Defender Source
Old July 17th, 2015, 11:37 AM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
I really hate..
to sound stupid, but don't these NAS D90's have a little electric fan to provide some additional air flow?
You can see it in this picture. (taken before I took off brush bar)
Attributed to Shayne...
Old July 17th, 2015, 11:44 AM
Departing90
Sasha
95 D90
The twin electric fans in the P38 are designed as pushers to cool the AC condenser. They won't push or pull enough air to cool your radiator. Even in the P38 owners had to upgrade them as they found them inadequate even for cooling the AC condenser. Even if that wasn't the case considering a 15 year old fan from a junk yard as your main cooling setup is playing with fire. Engine cooling is not where you want to save $ by compromising!
Old July 17th, 2015, 11:45 AM
My 97 with A/C had one. It is a last ditch before it overheats fan. It is set to come on at a pretty hot engine temp.
Old July 17th, 2015, 01:51 PM
Departing90
Sasha
95 D90
If you have the $ an electric water pump is also an option. It'll give you about 4-5◊ GPM more coolant flow at idle, You'll gain about 7HP at 3000RPM, you can have it running when the engines off, wont have to remove the fan clutch when wading and it has a lifespan of around 60K. You may have to upgrade your alternator for the extra power and have an adapter plate made.
Old July 17th, 2015, 02:12 PM
Understanding that an overheat can cause headgasket failure, what do you think is more likely: electrical failure or mechanical failure? your answer to that answers your posting question.
Mark Kellgren
KM4BOR
Old July 17th, 2015, 02:13 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
So here is a semi related question....if removed the Viscus fan and added an electric on a 19J...could I then mount a pulley where the fan was for an A/C belt and create some kind of bracket for the compressor?
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old July 17th, 2015, 02:16 PM
It sounds a simple answer....but.... There is a 100% failure rate on the viscous units from what I've seen. A well executed electric system will be as reliable. How many modern cars overheat due to failed electric fans?
Adding in a high temperature alarm is the best solution to prevent overheating. Very little cost.
Old July 17th, 2015, 02:22 PM
Can an ERC6859 be run on a 19J?
That seems like a cheaper way to have Adam get a pulley to drive a compressor.
Old July 17th, 2015, 02:26 PM
agree on the temp alarm, unless you are like me and have a vdo gauge staring at you in the face. I don't need no stinkin' alarm.
i think a failed viscous is much easier to identify during routine engine off maintenance inspection than an electric fan failure. And my days of chasing electrical gremlins in the field are over. never going back.
Mark Kellgren
KM4BOR
Old July 17th, 2015, 02:31 PM
It is all about the implementation quality. When done correctly, you will never have an electrical failure.
An audible alarm is the best. You normally should be looking outside and not at gauges.
Old July 17th, 2015, 02:47 PM
Ha! This coming from a TDI guy! I recommend this audible alarm model for diesel applications.
Mark Kellgren
KM4BOR
Old July 17th, 2015, 02:50 PM
rovertrader's Avatar
rovertrader
Dale
Is that a speaker or a snorkel to route air to cool the rad?!
Cop motor, Cop brakes- must be Cop snorkel!!
Old July 17th, 2015, 02:54 PM
It is not super loud in my truck. Wind noise is the biggest thing. I have a beeper for both high coolant and high EGT on mine. No problem hearing them.
Old July 17th, 2015, 03:18 PM
Dogpilot's Avatar
Dogpilot
James Wallace
Defender 90 1997 NAS ST
When I did my radiator, I replaced the viscous coupling as well, they are in the $40-60 range and they are about the most common part on the entire vehicle with other vehicles of non-Landy make. The only perhaps tricky part is the wrench for holding the viscous coupling shaft. It is thin wrench, but you can borrow it for free from the likes of AutoZone.
As for heat and overheating. Lets see last summer i spent three weeks in the Black Rock desert pulling a 7,000 lb roller with my 97 at 3-5 mph. It never even moved off the center of the cooling gauge, even running AC. If the concept isn't broken, don't change it to a new engineering solution.
Old July 17th, 2015, 03:21 PM
gilby's Avatar
gilby
1994 Defender 90
Originally Posted by Dogpilot View Post
When I did my radiator, I replaced the viscous coupling as well, they are in the $40-60 range and they are about the most common part on the entire vehicle with other vehicles of non-Landy make. The only perhaps tricky part is the wrench for holding the viscous coupling shaft. It is thin wrench, but you can borrow it for free from the likes of AutoZone. As for heat and overheating. Lets see last summer i spent three weeks in the Black Rock desert pulling a 7,000 lb roller with my 97 at 3-5 mph. It never even moved off the center of the cooling gauge, even running AC. If the concept isn't broken, don't change it to a new engineering solution.
Impressive!!
Old July 17th, 2015, 04:33 PM
Departing90
Sasha
95 D90
What a mess ! A high temp alarm is not " the best solution" for preventing overheating! A capable cooling system is on the other hand! You guys do realise that there is a 20 second give or take delay in the actual coolant temp and this alarm! A whole lot of damage can be done in that time! Maybe thats one reason manufacturers also dont agree.
Old July 17th, 2015, 04:39 PM
Obviously you want a good cooling system, but things fail. Viscous units, belts, water pumps, rads plug with mud... Endless amounts of possible reasons one day your engine will overheat. Knowing right away that the temperature is high (before it gets too high), lets you pull over and figure out what has failed. If you rely solely on the gauge, most likely you will miss that chance. Normally it happens while climbing a 5000 foot hard off road trail and the last thing you are doing is looking at gauges.
Old July 22nd, 2015, 05:48 PM
gilby's Avatar
gilby
1994 Defender 90
Went electric after all. Also found a cracked heater core in the process. Since my blower motor doesn't work, and I've been plenty warm in the winter, I bypassed it. I'll tackle that gremlin later. Needle nary wavers off midline now. Thanks to all!
G
Old July 23rd, 2015, 04:12 AM
lennix's Avatar
lennix
Lennie
1993/Defender Tdi200
While I believe that if you mainly do fairly light-weight leisure related work with your Land Rover in cool to moderate temperatures, it would be fine with an electric fan, I would personally at least opt for the clutch fan for this kind of vehicle. Considering that it would probably be cheaper for Land Rover to fit an electric fan from the start, Iím assuming that all aspects considered, the clutch fan setup is still seen as the best compromise. Likewise all other heavy duty 4x4ís that I know of employ a similar system despite the reliability of modern electronics. Personally I have a modified arrangement employing a Land Cruiser direct drive fan, which I recond has saved a cracked cylinder-head or two over the years. But I regularly use my Defender for demanding overland work in a hot climate.
Old July 23rd, 2015, 07:39 AM
ezzzzzzz
Mark Garrenton
I ran a 'black magic' electric fan on my '71 IIA with the Chevy 4.3 V6 as there was no room for a mechanical fan. While fording in the creek off Gregory Island at Pearl's Pond I dropped into a rather deep hole. Water came in through the grille. That influx burned up the motor and broke several blades. I was down and out until an overnight replacement came into Charlottesville. If you decide to run electric I highly suggest a dash switch and warning light to cut power to fan for fording. The factory fan and clutch work reliably when in good order. The noise and hp draw aren't that big a deal.
Injector Replace / Rebuild / Nozzle Replace icnsltmfg Defender Technical Discussions 8 April 29th, 2015 08:29 PM
SPAL 11" Electric Fan and X-Eng X-Fan Kit crown14 For Sale - Parts 2 February 5th, 2010 01:12 PM
Visc. Clutch vs Electric Fan snurp Defender Technical Discussions 27 June 5th, 2008 12:55 PM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 06:19 AM
D90 -- Fan clutch and fan Vadim Wanted 3 August 1st, 2004 01:00 PM
