Hello All,
I don’t post often-still a pretty junior mechanic and try to sort myself with previous threads. Stumped in this case and exhausted search. I’ in the middle of changing the LT230 seals as per: LT230 Seals - Defender Source. Got the rear seal swapped out fine, but in the process of removing the rear flange I broke a bolt. No problem, right, just replace with the new ones I have on the bench. Except I’m obviously an idiot because I can’t figure out how to remove the bolts; they are blocked by a circlip that I can remove and what appears to be a press fit lip that I am stumped by. What am I missing? Just need to use more finesse? Any help appreciated. Pics attached.
-brian
-brian
