Repeatedly blowing undehood 30A fuse - Defender Source
Old September 3rd, 2005, 04:18 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Ok, this is getting odd. I'm repeatedly blowing out the 30A under-hood fuse that's marked 'lighting' .
But every time it goes, I loose everything but the dash lights.
No power to the ECU, no power to the starter, no power to the distributor, no gauges.
But I can't figure out what the common connection is between the circuits.... unless maybe the ignition switch wires are on wrong, and it's using the lighting feed for the switch?
-Hans
Well, just tested every way I could think of and confirmed it.... The main fusebox under the hood on mine was wired backwards. The lighting fuse and ignition fuse wires are reversed at the box, so when I should have been going through a 60amp fuse it was going through the 30amp and probably just barely enough to fry it. My guess is that it's time for a new fuel filter and it's putting a bit more load on the pump, which makes sense since it always blew out during the first few seconds when the pump was priming the system for the first time.
-Hans
Scratch that, it's a short somewhere in the lighting circuit..... I'll deal with it tomorrow. At least it's narrowed down quite a lot for possible circuits.
-Hans
My oil line fix
My 100k stopped odometer fix
Old September 6th, 2005, 04:24 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
I had a sticky starter relay that was blowing one of my 30A's underhood. New relay two weeks ago, no 'stuck-engaged' starter and no blown fuse (so far...)
hood, wing
Fuel injection system Maxi fuse blowing ? TND90 Defender Technical Discussions 4 August 24th, 2009 12:32 PM
Blowing the gauge/brake light/blinker fuse R-C Defender Technical Discussions 3 May 20th, 2008 05:40 PM
Side lights fuse blowing owen Defender Technical Discussions 2 May 5th, 2008 10:59 AM
Blowing wiper/speedo fuse like crazy....help! P1CR Defender Technical Discussions 4 March 11th, 2004 03:23 PM
