Repair Shop Needed - Sacramento - Defender Source
Old April 17th, 2010, 05:35 PM
chrisconnie's Avatar
chrisconnie
Adam Hairston
97 LE #127/300
Searched and didn't find anything. Cerrones is just to far away to be practical.
Have a not so nice clattering coming from either the transfer case or trans. Truck still shifts fine and goes into lock hi/lo. But you can hear it pretty well from within the cab at idle if you lower the window. Sounds like a nut or something rattling around inside the case for lack of a better description.
Need someone with more knowledge than myself to diagnose before I go pulling things apart. If there is someone around Dixon that wants to take a listen and give some advice I will reciprocate with beer.
Thanks in advance.
Old April 17th, 2010, 05:55 PM
mpsteil
Michael Steil
NAS 110#23,97 ST#665
Is Rover Hybrids a little closer to you than Cerrones?. I have read good things about him on this site. Shane is his name I think. Have not seen him on the site for awhile though.
Old April 18th, 2010, 03:12 PM
chrisconnie
Adam Hairston
97 LE #127/300
Slushbox rattle at neutral w/ tcase in neutral. I banged on all the cats and they seem solid. Sure seems like a tcase issue but no problems on shifting. Super odd.
Thanks for the references. I am going to spend some more time trying to isolate then go somewhere.
Old April 18th, 2010, 10:34 PM
chrisconnie
Adam Hairston
97 LE #127/300
It sounds like something loose being tossed around in side one of the cases. I will try the neutral roll with both shifters and see what I hear.
Thanks so much for the diagnosis tips. Really appreciated.
Old May 2nd, 2010, 11:01 PM
chrisconnie
Adam Hairston
97 LE #127/300
JS;
Thx for the neutral tips. Based on that, and reading other threads I decided to pull the Y-pipe before paying for a professional. Noise went away. Cat needed to heat up a bit before rattling, that's why banging on it when cold produced no noise.
Thanks D90 Source!
ac
Body Shop/Rover Repair Needed chrisconnie Defender Technical Discussions 8 November 8th, 2009 11:57 AM
Fort Worth Repair Shop Referral UT_Cowgirl Defender Technical Discussions 5 May 22nd, 2009 07:40 AM
Independant repair shop in or near Greensboro, NC?? redhummer96 Defender Technical Discussions 13 March 19th, 2008 06:51 PM
Repair Shop, Mechanic Richmond VA dfscott Defender Technical Discussions 5 April 11th, 2007 10:26 PM
Portland Oregon LR Repair Shop kmg99 Defender Technical Discussions 3 May 17th, 2005 12:18 AM
