Removing Window Tint - Defender Source
Old April 18th, 2006, 08:50 AM
Grover's Avatar
Grover
Question Removing Window Tint
Anyone out there know how to remove window tint? I want to remove the window tint on my sliding door windows. Will a razor blade work?
95 D90 ST
Old April 18th, 2006, 08:55 AM
tkavan01's Avatar
tkavan01
Trevor K
94 d90 #1304
95 D90 ST
I'm interested in this too, but i want to do my back window, the tint reflects like a mirror, so every time a car is heading toward me from the front it looks like one is about to barrel into me from behind!
Old April 18th, 2006, 09:02 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Windex and a razor. Start at one end and lift it, spray large amounts of windex and peel back at a 45 degree angle. It's easy. Did the same to mine.
Old April 18th, 2006, 09:23 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Mine does this without tint, too. Just FYI. Been fooled many times!
Old April 18th, 2006, 09:53 AM
Grover's Avatar
Grover
Thumbs up
David and Chris,
Thanks for the reply. I get reflection from my windows too. When the are open to one side, they "double-up" making it very difficult to see out of, especially at night. Also, (this may be a dumb question) will the razor blade scratch the glass?
95 D90 ST
Old April 18th, 2006, 03:34 PM
d90xjay's Avatar
d90xjay
J Phillips
1997 D90 SW
Hmm, I've been wanting to add tint to my back windows for some time now to cut down on the reflections. Guess it doesn't help. I would have hated to install the tint only to find out reflections are still there.
Old September 28th, 2009, 10:03 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Is the stock NAS D90 windshield tinted?
If it is, how hard is it to remove the tint?
Mine is 14 years old now and has thousands of little pin pricks on it (from sand and dust blowing etc). I was hoping I could just re-tint the window and save myself from buying a new windshield. I was going to re-tint the rest of the windows so I might as well do the windshield as well.
Old September 28th, 2009, 10:29 PM
cdb
Clark Bowen
I just removed window tinting from 4 RR windows and what really made it easier was to buy a 4 - 5" wide window scraper with a handle. It is about 3 or 4 times wider than a regular razor-blade window scraper, so it cuts your time by about two thirds. Plus you can really push hard on it without the razor retracting.
2011 RR HSE -
2001 GMC 2500 4wd
Old September 28th, 2009, 10:45 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Not tinted as far as I can tell. You may want to try one of the winshield polishing kits from a place like Griot's or Eastwood, could be just the ticket.
I'm personally waiting for a nice bullseye rock hit to start cracking. Took the rock hit 3 years ago and it just doesn't want to crack enough that I can get the insurance company to replace the glass. Hopefully this winter.
-Hans
My oil line fix
My 100k stopped odometer fix
Old September 28th, 2009, 10:54 PM
Stock glass, when tinted, never have removable tint. As far as aftermarket tints, they're almost never applied to the windshield, and, as a rule, are only on the inside.
You're stuck buying a windshield, or asking your insurance company to buy one for you. They're not very costly.
Old September 28th, 2009, 11:44 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Damn. I think you're right Jim. It's not the answer I was looking for. I'll have to buy a new windscreen but since I have so many other things on my list of improvements, this little cosmetic issue is further down the list.
Thanks!
Old September 29th, 2009, 06:20 AM
disco dog's Avatar
disco dog
Tracy Dwyer
2002 D110 TD5
95 D90 ST
Single edge razor blades work fine for removing the plastic film, but you will need a can of 3M solvent for the glue, this makes it real easy.
Old October 4th, 2009, 08:20 PM
hutch's Avatar
hutch
Hutch
97 AA Yellow D90 ST
My Dad used to be in the tint business back in the 80s. The best thing to do is to get another sheet of tint or thin plastic sheeting. Spray a a solvent (not sure which kind but essentially a base to dissolve adhesive) on the tint and lay the plastic sheeting on the tint. Let it soak. The solvent will eventually soak through and loosen up the adhesive on the tint layer you are trying to remove. Then a good old 4" blade and scraper will do it. It's not easy but that trick should help a bit.
Old November 11th, 2009, 03:26 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Jim, I am getting ready to get all my D90 windows tinted. You were saying that if the glass is stock then the tint is non-removable, ie, part of the glass vs a film. Is this correct? The tint shop is asking if there is any tint that needs to be removed before the application of the new one.
I assume that this has to be taken into consideration when choosing the tint type because putting a tinted film on an already tinted glass might take your level of tint from legal to illegal, depending on the state's regulation.
Are the gaskets/rubber trim around the windows easy to remove? I have never done it and I want to make sure I give the tint shop some pointers, if any are needed.
Thanks!
Old November 11th, 2009, 03:37 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
someone told me WD40 works, haven't tried it yet..
Old November 11th, 2009, 04:11 PM
Thanks!
There are only two colors available as stock - clear, and blue-green. The blue-green isn't appreciably darker, but there is definitely a color-shift. If your original, stock, LR-supplied windows are tinted grey, then its got to be aftermarket, and thus removable. I don't think the difference between stock tinted blue-green glass and stock clear glass would be a consideration in the final darkness of the tint.
Which window gaskets are you talking about? Alpine windows and rear corner windows are held in with rubber seals, the back glass on a station wagon is glued in, the sliding side windows float in tracks, etc - I'm not sure what configuration you're dealing with or where you are putting the tint.
I should qualify all this by saying my only experience is removing aftermarket tints because I can't stand the stuff. It took a lot of adhesive remover, razor blades, glass cleaner, and time. Fortunately Tisdale wasn't home at the time so he didn't have to hear all the swearing.
Old November 11th, 2009, 04:45 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Thanks Jim. All my windows are stock. It looks like there is a blue/green tint to them. I'm talking about the sliding side windows, alpine windows, and rear window gaskets. I assume they will have to remove the rubber seals to access the glass in order to install the tint. Hopefully they won't have to disassemble the sliding glass on the side windows in order to install it. If they do, I want to make sure they put it back together properly and don't break anything. I can imagine they don't work on Defenders very often so I want to make sure they do it right.
Old November 11th, 2009, 05:07 PM
I couldn't tell from your pic if you had a station wagon or a soft top with a fiberglass top on it. Usually tint places are pretty good about getting tint right up to edges of glass areas, but lots or cars have those blackened areas around their glass which makes it easier.
I don't know what they propose, but I'm guessing they'll just do the windows by which ever method is easiest, even if it produces a sub-standard result. I doubt they'll take out any windows at all. Taking the glass out of the sliding windows is not a quick and easy job, meaning they'll: 1) not do it 2) fuck up the job 3) bill you heavily, or 4) all of the above.
You mention that you are assuming some stuff, which is bad. If I were you I would dedicate at least one trip to show them the truck, go over the various kinds of windows with an installer, and agree on the method by which they'll do the job (and the approximate bill). If they don't give you a good vibe at that meeting or are dismissive of your concerns, then go somewhere else.
Old November 11th, 2009, 06:39 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I would try to find a good local tint shop that high end consumers are using. A good shop will give you a lifetime warranty against bubbling and discoloration. They should stand behind their work, otherwise go elsewhere. I don't know all the tricks of the trade, but I have watched them do it a few times and it's really impressive. I just stay out of the way and I've never had a problem with the shop I use; they know what they're doing.
Removing it is really quite easy. All you need is a razor blade and an ammonia base window cleaner. The ammonia dissolves the adhesive and turns it into a soupy consistency that is easily removed with the razor blade, then just spray heavily with the cleaner again and wipe clean with a cloth.
Old November 11th, 2009, 06:41 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
It's a station wagon. I plan do it exactly as you described. Visit, pick out tints and go over the windows at the shop. Thanks!
vin, window
window tint? Roverowner Defender Technical Discussions 6 April 6th, 2017 08:19 AM
Removing rear sliding window from pickup cab dave_lucas Defender Technical Discussions 2 October 31st, 2009 07:49 PM
Removing window tops '97 D90 ST 1sttimer Defender Technical Discussions 10 September 25th, 2009 01:19 PM
shattered sliding window on d-90 prospector Defender Technical Discussions 5 January 16th, 2005 10:41 PM
st driver&passenger window bases fill with water Marc Weinstein Defender Technical Discussions 6 April 15th, 2004 06:52 PM
» Defender Registry
Meh-Teh
thewap
George
Hedgey
Add your Defender
