removing the tub cappings on a ST - Defender Source
Old December 4th, 2014, 06:09 PM
defender1844
Amit Likhyani
It looks like the threaded inserts where the fiberglass hard top would bolt in need to be removed. No big deal. I called RN to see if they had replacement nut zerts and they don't. Can anyone advise of the diameter/pitch/thread/part number and where a good place to acquire them would be? Looks like 7 per capping.
Thanks in advance for any advice.
Old December 4th, 2014, 06:20 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
They're nothing crazy...just an M8x1.25 nutsert. Fastenal is where I've always sourced them. Be aware that you'll need a special tool for installation.
-Ash
Geared Restoration Co.
352-572-3236
Old December 4th, 2014, 06:34 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
Originally Posted by defender1844 View Post
It looks like the threaded inserts where the fiberglass hard top would bolt in need to be removed. No big deal. I called RN to see if they had replacement nut zerts and they don't. Can anyone advise of the diameter/pitch/thread/part number and where a good place to acquire them would be? Looks like 7 per capping. Thanks in advance for any advice.
I don't think they all have to be removed. I was able to remove mine with a few still in place
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old December 4th, 2014, 06:51 PM
lordhelemt's Avatar
lordhelemt
Paul
That is you should be able to remove the cappings with the rivnuts in place. At least I was able to do that on mine.
Old December 4th, 2014, 07:01 PM
On a 95 they should come off without removing rivnuts.
vin
D90 cappings & tail lamp cappings Vieques Rovers Wanted 8 September 29th, 2014 08:35 PM
Galvanized 110 early tub top cappings SafariHP The Vendors Loft 11 March 23rd, 2009 10:49 AM
NAS 90 and 110 rear tub corner cappings FS SafariHP The Vendors Loft 15 January 24th, 2009 06:17 AM
D-90 SW tub cappings abraded Wanted 0 August 11th, 2008 05:04 PM
Removing LE Checker plate - Need help removing killer adhesive JimC Defender Technical Discussions 4 December 6th, 2004 07:24 AM
