Removing the Steering Wheel - Defender Source
Old October 2nd, 2007, 11:24 PM
61rover's Avatar
61rover
John Crouse
How do I remove the pad in the middle of the steering wheel? It doesn't seem to be covered in the shop manual.
Old October 3rd, 2007, 12:09 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
just pull, it will come off
Old October 3rd, 2007, 04:33 AM
If it is really truly stuck, and you dont feel like hitting yourself in the face with a steering wheel, go to sears and buy a steering wheel puller. If you dont feel like spendnig 20 measly bucks on puller, then just go back out to the truck and hit yourself in the face with the steering wheel.
Old October 3rd, 2007, 10:46 AM
The pad will rip its mounts off it you try to remove it.
Old October 3rd, 2007, 11:26 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
I have removed my pad many times with no ill effect.
Just pull.
Old October 3rd, 2007, 12:22 PM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
I too have pulled mine off before..... Popped right back on. Maybe evilfij has a different yanking technique?
"I race cars, play tennis, and fondle women, BUT! I have weekends off, and I am my own boss." - Arthur
Two issues here
1. Pad removal. I concur that you can safely pull it off with no ill effect.
2. Steering wheel removal. I suggest the wheel puller here too, although I don't see a good way to attach it. What does the puller grab onto on the back side?
charles
Old October 3rd, 2007, 12:34 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
My steering wheel puller comes with an assortment of bolts that bolt into the wheel. The center bolt pushes as the outer bolts pull. The "viola".
See attached.
Old October 3rd, 2007, 01:12 PM
Joe Cole
Joe Cole
97 D-90
Removing the steering Wheel
Here is offical technique from an LR Tech. Two ball peen hammners, loop one through the wheel flat face resting on the stud in the middle of the wheel. Pull the hammer handle towards you putting firm pressure on the rim of the wheel.
Take a second hammer and firmly rap it on the ball part of the first hammer while using you thighs to apply pressure to the bottom part of the wheel rim.
Sounds GOOFY, it worked with two blows of the hammer!
Old October 3rd, 2007, 01:17 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
That is a very technical approach. I can't recall ever having my thighs included as necessary in any other procedure related to maintenance on a Defender.
Old October 3rd, 2007, 06:38 PM
See attached.
Aah, I guess I didn't notice the threaded holes close to the center. I need to center my steering wheel, but first need to get the steering aligned. I'll try try the technical approach first, but might want to borrow your wheel puller if I have any trouble.
charles
Old October 3rd, 2007, 07:08 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
It's not a good idea to hit two steel hammers together. Since they are both hardened surfaces they often break into sharp pieces moving at high speed.
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
Old October 3rd, 2007, 07:54 PM
Mmh. I went out and took a look but I don't grok how or where to hammer per the instructions above.
I'm officially a fan of the wheel puller approach but the puller bolt holes are pretty small and fine threaded - I wonder of the kit has the right size. Can you check Greg?
Old October 3rd, 2007, 08:26 PM
Andrew Vick
Andrew Vick
95 D90
If you're taking it to get it aligned, they will center the steering wheel.
Old October 3rd, 2007, 08:28 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Actually Myth Busters did a show on this and found it to be a false myth!
Old October 3rd, 2007, 08:46 PM
Good point Andrew. I am considering trying to align it better myself first. It's just toe out after all. I want to double check my steering box is centered and the play taken out etc too. I just don't trust local shops to get all that done right. But yeah, I shouldn't waste any time pulling the steering wheel until thats all done (or I get a shop to do it). I just couldn't resist going out and giving it a try after reading this thread
Old October 3rd, 2007, 09:16 PM
61rover's Avatar
61rover
John Crouse
Removing the steering wheel
Thanks for all the input. I'm going to try pick up a steering wheel puller. The old wheel is on there pretty good.
The steering wheel on my D110 is really worn. It has been worn shiney smooth on 2/3 of it. I picked up a new wheel from a Td5 on ebay UK. It's going to look really cool.
Old October 3rd, 2007, 09:19 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
What are you doing with the old one? I have been looking for one at a good price to attempt a mod.
Old October 3rd, 2007, 10:46 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
I didn't do a show but I broke one myself. The piece missed me though. I took a coworker to the doctor to have a piece removed from his forearm when he wasn't so lucky on another occasion.
Maybe just faulty hammers?
Old October 3rd, 2007, 11:04 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Maybe you're just extra strong!
vin, wheel
removing steering wheel Hollywood Defender Technical Discussions 25 August 15th, 2010 03:16 PM
Steering wheel adapters Buckon37s Defender Technical Discussions 109 July 1st, 2007 09:19 PM
UK land rover steering wheel mpodgorski For Sale - Parts 2 February 1st, 2006 09:56 PM
Steering Wheel Sleeve mpodgorski Defender Technical Discussions 5 December 12th, 2005 10:46 AM
