Removing the Steering Wheel - Page 2 - Defender Source
Old October 3rd, 2007, 11:51 PM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
Originally Posted by cgalpin
I'm officially a fan of the wheel puller approach but the puller bolt holes are pretty small and fine threaded - I wonder of the kit has the right size. Can you check Greg?
Charles,
My wheel puller will work. I have used it several times on a stock D90 steering wheel.
Greg
Old October 4th, 2007, 08:03 AM
Cool, maybe we can just do it real quick next time we have a 101 wrenching party.
charles
Old October 6th, 2007, 10:30 PM
61rover's Avatar
61rover
John Crouse
D110 Steering Wheel
Hey Andrew. I'll sell you my old one cheap if I can get the new one on this weekend. How's $35 sound?
Old January 16th, 2011, 09:15 AM
ssbartley1's Avatar
ssbartley1
Steve Bartley
1997 SW #160
So- I read through this thread to figure out the best method to remove my steering wheel- and after a few hits with a hammer...i opted to for buying a steering wheel remover. Of course....after I opened the package... I realized that the bolts were the wrong size. (typical). A few hits of PB Blaster and two hits on either side of the wheel with a hammer - popped right off.
Steve B-
Otterberg, Germany
"Walk tall, kick ass, learn to speak Arabic, love music and never forget you come from a long line of truth seekers, lovers and warriors."
- Hunter S. Thompson
Old January 16th, 2011, 09:34 AM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
Originally Posted by snuffer View Post
It's not a good idea to hit two steel hammers together. Since they are both hardened surfaces they often break into sharp pieces moving at high speed.
You must work for OSHA lol
Old January 16th, 2011, 11:16 AM
bjf's Avatar
bjf
barry f
94 ST #395
I made my own puller. Total ghetto but a piece of flat bar metal. Drilled two holes. Put it over the center. Tightened a bolt through each hole and it came right off. Of course I didn't put The wheel back on straight but that is a different issue.
Old January 16th, 2011, 03:59 PM
ssbartley1's Avatar
ssbartley1
Steve Bartley
1997 SW #160
dang it
I think I can rig something up for the one I bought, it was only $16, so Im not heart broken. While I was at it i took the column apart and found out that the headlight switch that I just about ordered was perfectly fine, the retaining nut popped off. It works good as new now.
Steve B-
Otterberg, Germany
Old November 12th, 2011, 01:16 AM
brettm's Avatar
brettm
Brett
97 D90-SW, Arles +4.6
where did i go wrong...
my wheel will not move. wd40. double-hammer with knees technique, smacking the life out of the back with rubber hammer, crazy juggling in every direction... nothing.
sadly my "build your own ghetto pullers" skills are clearly not as strong as barry's.
i tried to make my own puller... three of them; all documented in the attached picture.
granted, the first one was a bit optimistic, but v3 was pretty strong... but no movement at all, just trashing of my ghetto pullers.
before i go buy a real puller, or break out the sawzall... any other words of wisdom?
Old November 12th, 2011, 09:51 AM
bjf's Avatar
bjf
barry f
94 ST #395
Amazingly ghetto. Why bother with the center bolt?
Mine was a flat piece of metal with two holes. Just cranked bolts through each hole into wheel with the center of the plate over the main wheel bolt. Do it slowly, alternating tightening and the wheel will pop
Old November 12th, 2011, 11:42 AM
brettm's Avatar
brettm
Brett
the only right sized bolts i had for the puller-holes were philips-heads, which would be hard to crank... and i was feeling too lazy to run to home depot. figured the center-bolt would mimick a puller-design... doesn't seem like it should need THAT much force though... i'll go get some hex-heads and try again...
Old November 12th, 2011, 02:36 PM
bjf's Avatar
bjf
barry f
94 ST #395
Without the hex heads it won't work. Some people don't need the puller but I have never been able to remove one without it
Old November 12th, 2011, 05:39 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Loosen the big centre bolt but don't take it right off. grad hold of the wheel at the 3 and 9 o'clock position, rock the steering wheel whilst pulling firmly upwards. Leaving the centre bolt on prevents you smacking the wheel into your face when it suddenly breaks free. Never failed me. I do have a home made puller and it does have a centre bolt that pushed down o the column. If the wheel is really stuck I'd use the puller and pull too.
Mike Hammond
Old November 13th, 2011, 02:02 AM
brettm's Avatar
brettm
Brett
done. took some lump-hammer persuasion in addition to a barry-style "two-bolts and a plate puller".
Old October 15th, 2013, 09:33 PM
azarmadillo's Avatar
azarmadillo
Chad Manz
1991 Range Rover Hunter
What size are the bolts needed to thread into the steering wheel?
Old October 16th, 2013, 04:06 PM
mikeslandrover
Mike Hammond
M6 I think.
Mike Hammond
Old October 16th, 2013, 04:37 PM
azarmadillo
Chad Manz
I got lucky and the first bolts I tried fit. If anyone wants to know the size, I'll check them next time I'm at the hardware store.
vin, wheel
removing steering wheel Hollywood Defender Technical Discussions 25 August 15th, 2010 03:16 PM
Steering wheel adapters Buckon37s Defender Technical Discussions 109 July 1st, 2007 09:19 PM
UK land rover steering wheel mpodgorski For Sale - Parts 2 February 1st, 2006 09:56 PM
Steering Wheel Sleeve mpodgorski Defender Technical Discussions 5 December 12th, 2005 10:46 AM
