Removing the injection pump - Defender Source
Old October 17th, 2015, 02:27 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Engine is a disco 200tdi. I need to remove the pump so I can remove the timing case and replace the seals. The shop manual talks about locking the injection pump with a screw after removing the keeper plate. My pump has a bolt in the same area shown but does not appear to have a keeper plate. I also have a 300 tdi in my garage that doesn't appear to have a keeper plate either. Am i missing something? I want to lock the pump as described to minimize timing issues after reassembling. Any help appreciated.
ID:	132537   Click image for larger version
ID:	132539   Click image for larger version
Old October 17th, 2015, 02:29 PM
If you are just removing the timing case, the pump can stay attached to it.
Old October 17th, 2015, 04:12 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
There is no need to remove the injection pump, I take it you have the timing pin fitted? Once the pump hub is removed you then remove the three nuts that hold the inj pump to the timing case and bob's your uncle.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old October 17th, 2015, 05:50 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Red, I thought of leaving it attached but seems it would be awkward to slide the case off the crank with the weight of the pump. Roverman, are you saying the case will come off with the injector pump in place, i.e. the pump will just hang from the rear bracket?
Old October 17th, 2015, 07:02 PM
roverman2010
1985 LR 90 200Tdi
That's a fact Jack, that is how it is done.
Pictures of a D1 I did recently
ID:	132561   Click image for larger version
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old October 17th, 2015, 08:23 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Awesome, i really had no interest in removing the pump..
vin
200 Tdi injection pump settings ... Retrofit Defender Technical Discussions 0 March 22nd, 2010 10:19 AM
Defender 200Tdi injection pump ... Retrofit Defender Technical Discussions 2 March 9th, 2010 10:11 AM
200 Tdi injection pump removal ... Retrofit Defender Technical Discussions 3 October 28th, 2009 01:29 PM
harness on 300 tdi injection pump Abrooks Defender Technical Discussions 5 February 22nd, 2009 12:27 PM
Removing LE Checker plate - Need help removing killer adhesive JimC Defender Technical Discussions 4 December 6th, 2004 07:24 AM
