removing the glass from door tops? - Defender Source
Old September 30th, 2009, 10:03 AM
DonFromWhitby
Don Andrews
'94 NAS D90 #CDN-80, 2011 LR4
I have a friend with a 101 and his door channel stuff (felt?) is all rotted out. He wants to replace it, but can't figure out how to remove the glass out of the door top.
Any ideas?
Old September 30th, 2009, 10:54 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Just like a Series truck.
Remove/grind out the little screws in the middle of the upper tracks, then the slider window and its track will slide to the inboard side and you can lift it out. Then undo all the screws and retainers to remove the fixed window.
A cut off wheel is usually the best too to remove the screws from the tracks if they are rusty, the heads usually strip or break.
Email:
door, door tops, glass, vin
POE Lift Gate and Glass TDI Guy For Sale - Parts 11 May 25th, 2006 05:02 PM
question about fiber glass hard top? naeirie Defender Technical Discussions 3 March 29th, 2005 10:14 AM
Removing LE Checker plate - Need help removing killer adhesive JimC Defender Technical Discussions 4 December 6th, 2004 07:24 AM
I need front winsheld,right fender black flare, rear door glass. Vadim Wanted 2 July 23rd, 2004 11:47 AM
windscreen glass & door skins mattdh Defender Technical Discussions 8 March 9th, 2004 08:23 PM
