Removing the bulkhead on a 110 regular tub - Defender Source
Old August 12th, 2010, 05:45 PM
So Barry sold me his "W" bar and I have the two other bits that are vertical from Lane and I want to do this:
http://www.eastcoastrover.com/148.html
Any tips or should I break out the sawzall and report back later.
Old August 12th, 2010, 06:00 PM
bjf's Avatar
bjf
barry f
94 ST #395
http://www.eastcoastrover.com/148/3.jpg
Looks like pilot holes were drilled and the cutting follows that line
Old August 12th, 2010, 07:23 PM
bjf's Avatar
bjf
barry f
94 ST #395
You need this. http://www.blairequipment.com/Spotwe...d_Cutters.html Its really easy for a sawzall to grab and bend the Aluminum sheetmetal, if you really want to cut it use a nibbler.
-Jeff
Edit: so I guess this meant you found a 110regular tub. Ive been looking (though not too seriously) for a while now. Care to share your source?
That looks like what I need to drill off my sills? Can I get it anywhere?
Old August 12th, 2010, 08:05 PM
EWR's Avatar
EWR
Carey
1954 CJ-3B
For a large quantity of a certain Black and Tan, I could point you in the right direction
What tree?
Old August 12th, 2010, 08:11 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
A grinder might help too. It would create lots less stress than a sawzall.
I really like the large rear sliding windows and think that would be a nice addition to the 3 door truck.
Old August 12th, 2010, 08:16 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Sawzall on the last one I did... Also used a small air saw to get in the tight spots...
Legend in My Own Mind.
Old August 12th, 2010, 09:19 PM
Jsbriggs. I bought a whole 110 from the uk to get the tub.
Thanks for the tips.
Ron
Old August 13th, 2010, 01:06 PM
bjf's Avatar
bjf
barry f
94 ST #395
Sills? Are you talking about the body colored aluminum under the door, or the steel peice that supports the floor? Either one shouldn't be spot welded, just bolted and riveted. But to answer you question, they should be fairly easy to find in ElEh, if not you can get them online.
-Jeff
sills spot welded to t supports under doors
Old August 13th, 2010, 01:16 PM
Yes, you need that and an angle grinder and an air chisel will probably help too.
Ron
110, vin
Series tub vs 110 tub MUDSUX Defender Technical Discussions 7 March 4th, 2010 10:50 AM
bulkhead LHD 1993 defender 110 non ac with extras haaseizhere For Sale - Parts 15 March 4th, 2007 10:23 PM
Looking for 110 CSW tub. C-Delta Wanted 2 December 7th, 2004 07:43 AM
