removing steering wheel - Page 2 - Defender Source
Old August 2nd, 2010, 01:06 PM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
It's been a long time so I might be wrong. But, do you have the big bubber bumper pad that's all black, like on a 97 d90?
If so, you can just pull it, and it will pop off.
http://www.google.com/imgres?imgurl=...A5SmsQPzu6jaAg
Old August 2nd, 2010, 01:11 PM
District 90's Avatar
District 90
BENJAMIN/LEE
1994/DEFENDER 90
130Tdi: to rephrase: Do you remove the front rubber steering wheel cover from the back of the wheel first or from the sides?
District 90
Old August 3rd, 2010, 05:55 PM
District 90
BENJAMIN/LEE
1994/DEFENDER 90
removing the steering wheel
Removing the rubber pad was not a problem: pull the edges and slide it up.
I'm using a wheel adapter and managed to get 17% off the center column. The '94 requires a 2 X 6 mm bolts on the 12 and 6 openings. Tried using a soft mallet gently on the back of the wheel. Even a drumroll cadence on the 3 and 9 from old school hip hop to the hula. Pushing in/out was another option. It still will not budge. Any other techniques/suggestions?
Is it wise to use 10WD40 in this situation?
Old August 8th, 2010, 12:03 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Undo the nut that holds the wheel to the column but leave it on a couple of turns. Rock the wheel from the 3 and 9 o'clock hand positions whilst pulling up at the same time, it usually pops off after a while. Leaving the nut on but loose stops you hitting yourself in the face with the wheel when it breaks free suddenly.
Hope this helps
Mike Hammond
Old August 9th, 2010, 12:20 AM
crobinson
Chris Robinson
97' D1
Sorry for the thread highjack.
Will a NAS D90 steering wheel fit a NAS D1 (without airbags)?
Old August 15th, 2010, 03:16 PM
District 90
BENJAMIN/LEE
1994/DEFENDER 90
Thumbs up removing the steering wheel
Tanks for the advice, fellas.
Removed it with a Y-adapter. Best to keep the nut on.
vin, wheel
Steering wheel adapters Buckon37s Defender Technical Discussions 109 July 1st, 2007 09:19 PM
Removing the Steering Wheel - no swearing involved Captain Spalding Defender Technical Discussions 2 May 9th, 2006 07:19 AM
UK land rover steering wheel mpodgorski For Sale - Parts 2 February 1st, 2006 09:56 PM
Steering Wheel Sleeve mpodgorski Defender Technical Discussions 5 December 12th, 2005 10:46 AM
