Removing Salt (road salt / beach salt) - Defender Source
Old January 1st, 2013, 07:27 PM
Rufus's Avatar
Rufus
Rufus
1994 NAS D90 ST #1118
other than pressure washing, what is the best solution for removing salt from the frame, etc. Ideally a solution that can be sprayed underneath where it is hard to get a brush. I have read about adding baking soda or white vinegar to water - does this really work? Or are you better off just using a good soap solution -if so whats the best? I am looking for a solution that will work better than water on its own. Any thoughts/suggestions would be appreciated. Thanks
"Sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place"
D90 Yahoo Group member since 2001
Old January 1st, 2013, 07:31 PM
I've heard that a good method is to get one of those rotating sprinklers that you use on the lawn, the kind that go back and forth vertically, throw it under the rig and run it awhile. That's my plan. Just came back from ski vacation and need to pick one of these up. Key is to do it sooner than later, before the oxidation can begin.
Mark Kellgren
KM4BOR
Old January 1st, 2013, 07:46 PM
madcowdungbeetle
Carter
Make sure the drain holes are all unplugged and jam the pressure washer nozzer in the frame horn, under the gas tank, and all up in the rear cross member.
Old January 1st, 2013, 08:12 PM
jac04's Avatar
jac04
Jeff
Currently Roverless
Eastwood makes some stuff called Road Salt Neutralizer. Never used it, so I have no idea if it actually does anything special. Here it is:
http://www.eastwood.com/eastwood-roa...er-gallon.html
Old January 1st, 2013, 11:39 PM
hamiamham
mike
97 D-90
have had good luck with a product called salt-away. www.saltawayproducts.com
Old January 2nd, 2013, 01:23 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I spray everything I can reach with WD40. So far so good. I have no scientific reasoning for why its working but over the past 8 years I've yet to see any rust develop.
Clay
Old January 2nd, 2013, 07:58 PM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
WD 40 is water displacing attempt number 40. Spray it on and water is displaced not not allowed to sit and cause rust
Old January 2nd, 2013, 10:18 PM
Fresh water and lots of it. That and warm weather to dry it quickly.
Old January 3rd, 2013, 10:25 AM
michael67's Avatar
michael67
Michael White
110 Tdi
I just go to one of those car washes that have an underbody wash after returning from up north over Christmas. I did that with my old CJ too and it never seemed to develop much rust.
ac, vin
northeast states that dont use road salt??? crown14 Misc. Chit-Chat 10 November 2nd, 2009 08:28 PM
Road Trip Report, Defender Sightings chris snell Misc. Chit-Chat 5 December 28th, 2005 03:03 PM
1994 Land Rover Discovery, ready for off road SBA For Sale - Vehicles 4 August 24th, 2005 11:28 AM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
