Removing Rhino Liner? - Defender Source
Old November 3rd, 2007, 10:39 PM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
What is the best method of removing RhinoLiner or similar coatings?
Would Sand/Media blasting work, or is it to thick of a coating?
Gary
Old November 3rd, 2007, 10:41 PM
I would run by a shop that sells it and ask them... I am sure they have over sprayed something and they had to remove it.
A torch and a scraper may work too...
Old November 4th, 2007, 08:46 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
I asked Rhino Liner that one time and they asked me why I would want to Anyway, they didn't have a good answer. I had paint remover I had gotten from Eastwood for Aluminum (aircraft). Liberally applying and allowing it to soak in, the rinoliner lifted up and could be pulled away like a rubbermat (at least in most places). In some it required the addition of a scrapper. Bottom line - it isn't easy and you will have to soda blast(which I suggest for aluminum) and reprime and repaint.
Old November 4th, 2007, 11:00 AM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
Sounds like a messy process, but that is what I have read several places now. I am going get some of the Aircraft Coating Remover and try it in a spot and see how well it works.
Gary
Old November 4th, 2007, 11:10 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Seems to come off easier on vertical sections where the Rhino liner is thinner.
vin
For those of you with Rhino -Liner. Quimbola Defender Technical Discussions 2 January 22nd, 2009 03:23 PM
Removing LE Checker plate - Need help removing killer adhesive JimC Defender Technical Discussions 4 December 6th, 2004 07:24 AM
Rhino Lining boshea Defender Technical Discussions 7 November 4th, 2004 08:55 PM
Rhino Lining a defender Dfndr90 Defender Technical Discussions 13 August 6th, 2004 08:52 PM
speed liner or rhino liner TDI Guy Misc. Chit-Chat 5 May 5th, 2004 09:27 PM
