Removing Rear Wiper - Defender Source
Old February 4th, 2013, 03:33 PM
aaronlam's Avatar
aaronlam
aaron lam
1997 Alpine White D90 SW #2212
Removing Rear Wiper
Hi All,
I've got a new style rear door I am trying to get painted. Trying to remove the wiper but just can't get it off. Any ideas or tricks?
I followed the manual and removed the nut behind the cap at the end. PB blasted and pulled but nothing. Some people said hit it with a mallet but there's not even really a place to hit it.
Thanks for the help.
aaron
ID:	65714   Click image for larger version
Name:	D90-Workshop Manual.jpg
Old February 4th, 2013, 03:49 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
See photo.
Old February 4th, 2013, 04:09 PM
aaronlam's Avatar
aaronlam
aaron lam
Yes... but that nut only holds the wiper arm onto the door. I assume (as there was no way to remove the wiper arm from the motor on the other side) that wiper arm must come off that bolt so it can pass through the hole.
There was a nut above the wiper arm that I removed already. In all logically senses... that would allow to slip off. Maybe I am not using enough force....
I couldn't find a release tab or anything either. Nothing was mentioned about a tab for the REAR wiper in the manual.
Old February 4th, 2013, 04:12 PM
grnrvrs's Avatar
grnrvrs
Paul
88
A bit more careful force or a small puller will pop it right off. The spindle has fine splines.
1970 SIIA 88, Sold
Old February 4th, 2013, 04:32 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
This is a conical fit, they do get stucked often. A small 2 legs extractor is the best way, otherwise a spanner with a leverage point.
- Charles Eames
Old February 4th, 2013, 04:34 PM
aaronlam's Avatar
aaronlam
aaron lam
Barry gave me a suggestion that worked... loosened that nut that holds it to the door... and then hit the top of the bolt into the door and forced the arm to pop off. Did take some good pounding though...
Thanks!
vin
Defender rear door wiper CDNRover For Sale - Parts 1 December 24th, 2010 11:53 AM
d90 sw rear wiper motor and arm lspindler5 For Sale - Parts 1 August 7th, 2010 10:41 AM
d 90 sw rear wiper motor, bracket and arm lspindler5 For Sale - Parts 5 July 21st, 2010 04:49 PM
weak rear brakes? redrover Defender Technical Discussions 12 April 28th, 2006 09:24 AM
Rear Wiper - Anyone Please Kimos Defender Technical Discussions 14 November 8th, 2005 02:10 PM
