Removing rear trim panel - Defender Source
Old January 1st, 2013, 08:14 AM
Langley90
Gio
97,Defender 90
I just got a new set of replacement tail lights for my defender 90,I am not sure how to remove the rear trim panel to access the the back of tail light for removal and installation. Any input would be greatly appreciated.
Old January 1st, 2013, 09:23 AM
You can change the lights from the outside. All the connectors are under the truck. Remove the two screws on each of the rear lights, then carefully twist and disconnect the bulb from the back of the light housing.
Old January 1st, 2013, 05:42 PM
Langley90
Gio
97,Defender 90
Thank you!
vin
Defender Rear Tub Panel, aluminum fuel tank cradle pacificwildfire Wanted 2 October 12th, 2011 06:22 AM
Rear Door Interior Panel 61rover For Sale - Parts 0 December 7th, 2009 10:58 PM
Removing rear sliding window from pickup cab dave_lucas Defender Technical Discussions 2 October 31st, 2009 07:49 PM
97 D90 SW - Inner rear door panel Kimos Wanted 5 December 2nd, 2004 09:26 AM
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
» Defender Registry
Landy
x-pat
Big Red
jec
Add your Defender
