removing rear crossmember bolts-easy? - Defender Source
Old July 4th, 2009, 03:36 PM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
anyone invented an easy way to remove the rear body bolts without dropping the fuel tank?
well...after much due consideration...I don't know if those rear crossmember bolts are all supposed to be captive but only two of mine were...but, you can get the ones near the ends by reaching in with a wrench from under the crossmember and ratcheting the outside bolt head...the middle two require figuring a way to place the open end wrench from the small slot area left open between the rear tub and the top of the crossmember...then ratchet the outside bolt head...I attached a "handle" at right angles to the wrench with a pair of needle nose pliers...felt for the wrench seating as I rotated the bolt head and then wrenched it open...quicker than dropping the fuel tank and makes it easier to access the fuel tank if you're already pulling the rear tub as I am...hopes this helps someone in the future...
Old July 4th, 2009, 03:40 PM
The outside pairs are nuts and bolts, the inside 6 are captive nuts.
Old July 4th, 2009, 03:55 PM
Gkase's Avatar
Gkase
George Kase
just my luck of course, mine weren't captive...made things more difficult as noted above...
bolts, vin
Removing Rear Step Bumper TurkD90 Defender Technical Discussions 16 July 20th, 2008 09:42 PM
Removing Seat Track Bolts! JimC Defender Technical Discussions 5 November 5th, 2004 03:15 AM
D-90 Rear crossmember neo812 Wanted 2 August 1st, 2004 02:29 PM
Rear Bumper bolts? Quimbola Defender Technical Discussions 2 July 16th, 2004 11:30 AM
