Removing ram housing - Defender Source
Old December 21st, 2011, 12:39 PM
Lindy's Avatar
Lindy
Eric Lindstrom
1994 d-90 #1444
Anyone have any suggestions for removing the ram housing from my 94 d90? I've got all six bolts out and all the hoses off but this #@%$&!@er just won't budge. I'm in the process of swapping out the fuel injectors.
Eric
Old December 21st, 2011, 12:51 PM
Grover's Avatar
Grover
Eric
If you mean the upper intake manifold, take a flat head screwdriver as a wedge and work the edges of the intake manifold. Work all four corners a little at a time and it will break free. Be very careful not to scuff the heads...
Good luck
Old December 21st, 2011, 01:02 PM
hit it from the side with a rubber mallet to break the sealant-sounds like some one used lots of sealant on yours
Old December 21st, 2011, 01:03 PM
Lindy's Avatar
Lindy
Eric Lindstrom
1994 d-90 #1444
Thanks guys, I'll try both methods.
------ Follow up post added December 21st, 2011 01:18 PM ------
Rubber mallet took care of the problem. Thanks for the help !
Eric
Eric
vin
D-90 air filter housing cap needed (horn) arbik Wanted 4 November 30th, 2010 12:45 PM
Long post regarding CV Joint/Swivel housing.. Emerson00 Defender Technical Discussions 16 June 12th, 2007 09:11 AM
Removing LE Checker plate - Need help removing killer adhesive JimC Defender Technical Discussions 4 December 6th, 2004 07:24 AM
How to get d--- fuel pump housing back in NAS tank? Chris Cox Defender Technical Discussions 3 October 29th, 2004 09:58 AM
Air Filter Housing mgrgpg Defender Technical Discussions 1 December 20th, 2003 01:48 PM
