Removing LE Checker plate - Need help removing killer adhesive - Defender Source
Old December 5th, 2004, 08:48 PM
Has anyone every removed the checker plate bits from the running boards or rear ladder of a LE 97 SW? The stuff is bonded on with some sort of structural adhesive. It doesnt seem to be responding to the 3M adhesive remover.
Ideas anyone?
Old December 5th, 2004, 09:26 PM
Try a heat gun and a hard plastic scraper. I have found that with enough heat you can remove about anything....
Old December 5th, 2004, 10:23 PM
Iam interesed in the running board plating if you get rid of it
Old December 5th, 2004, 10:34 PM
Kimos's Avatar
Kimos
Larry O'Hara
1997 Defender Wagon
I agree Jim, heat should loosen it. The remaining adhesive will come off easily with Tarminator - a product made by Stoner
ref: http://www.defendersource.com/forum/...ghlight=stoner
Been using their products for 8 years. Safely remove adhesives, mastic, tar, grease, overspray etc . .. without hurting cured painted surfaces. Get some of the stuff and keep it around the shop. You'll wonder how you ever lived without it.
http://www.moreshine.com
Old December 6th, 2004, 07:24 AM
Thanks guys, I was worried that heat would be my only option - now I have to go buy a heat source...
And I got the running boards explicitly for the purpose of using the plate - go find your own LE checker plate running boards!
vin
5 bar checker plate -2mm mattdh Wanted 2 May 24th, 2005 04:01 PM
4 SALE: Checker plate side sills roverboy For Sale - Parts 5 October 12th, 2004 08:16 PM
Checker plate (not diamond plate) needed. hank17 Defender Technical Discussions 4 September 15th, 2004 02:16 PM
checker plate - reshine paulb Defender Technical Discussions 4 January 8th, 2004 05:57 PM
5-bar checker plate wing top protection ronward Defender Technical Discussions 8 October 27th, 2003 10:42 AM
