Removing large red nutsert from front panel/grill mount - Defender Source
Old March 16th, 2016, 08:57 AM
ymc226
Lawrence
1995 D90 SW NAS
Just got Jason's great front grill and want to start with new nutserts as it is heavier than the plastic OEM piece and want a tighter grip.
Bought the Proline replacements from Rovers North (PLC946) PLASTIC NUTSERT SERIES & DEFENDER, RNC946, CZA4705L,PLC946 - Rovers North - Classic Land Rover Parts but can't get the old ones out as they are pressed in very tightly.
Would you drill out the old pieces? I just don't want to damage the panel in trying to remove.
Old March 16th, 2016, 09:05 AM
The Dro
Dro
1988 Ninety
I used channel lock pliers to press them out.
Old March 16th, 2016, 09:24 AM
ymc226
Lawrence
1995 D90 SW NAS
Stupid question but do you reach in behind the panel and press the ends of the nutsert together using the pliers? I think I tried that with regular pliers and it was a no go.
Old March 16th, 2016, 09:28 AM
The Dro
Dro
1988 Ninety
I removed the whole breakfast and took some out. Jason (nathawind) did the rest.
You press them with the channel locks and they will slide out
------ Follow up post added March 16th, 2016 09:29 AM ------
Most will break... Mine were brittle
Old March 16th, 2016, 09:32 AM
The Dro
Dro
1988 Ninety
Press here and slide out.
Old March 16th, 2016, 09:34 AM
ymc226
Lawrence
1995 D90 SW NAS
Thanks very much. Will try tonight.
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I used some curved needle-nose pliers to squeeze and wiggle.
Get enough through the front, then push/pull until they're free.
It's easier after you do a few and it helps to be above 50*F...
Rent my
Old March 16th, 2016, 09:39 AM
I cut them off from the rear using big nippers.
Old March 16th, 2016, 10:05 AM
The Dro
Dro
1988 Ninety
That works too.
Old March 16th, 2016, 10:15 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
I just smack them with a rubber mallet...
Old March 16th, 2016, 02:24 PM
PabloCocito's Avatar
PabloCocito
Pablo Cocito
1987 Defender Tithonus
You can drill them out? They should fall right out after
Old March 16th, 2016, 02:49 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I should clarify--- I was reusing mine.
Obviously, if you just need them out then snip or drill....
Rent my
mount, vin
Brush Bar used for sale and Front grill Red generalcutter For Sale - Parts 4 February 28th, 2016 08:57 PM
Upright Bracket special metal nutsert things BMGmotors Defender Technical Discussions 4 June 1st, 2011 12:43 PM
NTO front grill panels w plastic grill in white SafariHP The Vendors Loft 0 February 19th, 2009 09:46 AM
NAS 110 front speaker and grill, NAS 110 front grill panel (stick out type) evilfij Wanted 2 March 27th, 2007 10:59 AM
Removing LE Checker plate - Need help removing killer adhesive JimC Defender Technical Discussions 4 December 6th, 2004 07:24 AM
