Removing jump seat mounts/bolts - Defender Source
Old November 17th, 2013, 05:14 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Has anyone found an easy way to remove the SW jump seat mounting brackets? The bolts go through the tub and you can access the nuts through the rear wells - mine are totally seized, huge nightmare.
Can anyone recommend a good tool/saw to cut bolts in a small space?
-Ren Ching
Old November 17th, 2013, 05:16 PM
Jbullis's Avatar
Jbullis
Jason Bullis
1994 NAS 90 #1810, 2006 LR3
PB Blaster, just soak them....
Old November 17th, 2013, 05:34 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Mine were a bear to remove as well. Id put a big vise grip on one side and air ratchet the other side until they come off or snap off.
Old November 17th, 2013, 05:55 PM
smob's Avatar
smob
Steve
I did, but you have to get someone else to hold the wrench on outside and wife isn't interested in the slightest.
------ Follow up post added November 17th, 2013 05:56 PM ------
Damn, that's a good idea. I'll give that a shot. Thanks.
-Ren Ching
Old November 18th, 2013, 08:58 AM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
reciprocating saw and metal cutting blade
Old November 18th, 2013, 09:03 AM
I replaced mine with rivnuts. Seatbelt does the load bearing. Those brackets can kiss my ass.
Mark Kellgren
KM4BOR
Old November 18th, 2013, 09:38 AM
smob's Avatar
smob
Steve
I could do that, but it's a super tight space underneath - can you think of a good small one that might work? How about a dremel? Do they have good metal cutting circular blades?
I was contempating a 4.5 inch angle grinder but that scares the crap out of me in such a confined space.
------ Follow up post added November 18th, 2013 09:39 AM ------
Agreed, they suck ass - rivnuts not a bad idea.
-Ren Ching
Old November 18th, 2013, 09:48 AM
Happy hour? I can hold a wrench in one hand and a beer in another. Mad skills as the kids say (although it took years of practice to achieve).
Originally Posted by pendy
I'm here for the D's
Old November 18th, 2013, 09:53 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
I use a Dremel all the time...they have good blades but don't do weird angles well. Good stuff just be careful and safe.
Old November 18th, 2013, 09:56 AM
smob's Avatar
smob
Steve
Ha - I actually think the wife has book club that night, but let me check. It's been years since I've been to HH.
-Ren Ching
Old November 18th, 2013, 02:28 PM
95beluga's Avatar
95beluga
brian colby
1995 NAS D90 #1997
Hello All,
I'm a new poster to the forum but have lurked for years.
I just removed two jump seats with completely seized bolts. I tried all the suspects mentioned above and I second the use of a dremel as the best tool. and many, many cut off wheels; like 45 or so for two seats plus belts. i found that the quick release wheels are faster to work with and using a flexible shaft attachment helps a bunch.
Good luck!
Old November 18th, 2013, 03:09 PM
Welcome Brian
That sounds painful. I bet it's just a couple of minutes with a grinder (if it comes to that). No way would I bother with a dremel.
Old November 18th, 2013, 06:01 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Fire up the sparkly spanner.
Mike Hammond
Old November 18th, 2013, 06:16 PM
smob's Avatar
smob
Steve
Welcome Brian
I'd go with a grinder for pretty much any bolt except for these - they're seized enough that you can't get make progress inside the truck and you'd need to go underneath.. And even the smallest grinder I've seen would likely be a hazard for me (I have bad neuralgia in my right hand). So yeah, it's either find a patient person to help out or use some other cutting tool that I can control more easily.
-Ren Ching
Old November 18th, 2013, 07:23 PM
I did this on two NAS110s. I thought about cutting them off, but what I ended up doing was big vice grips under and a 1/2in drive rachet with long extension on top. The vast majority snapped easily.
Old November 18th, 2013, 08:10 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Steve, bring it by over the weekend and we can apply air tools and grinders as necessary.
Old November 18th, 2013, 08:13 PM
smob's Avatar
smob
Steve
Ooooh.. I may take you up on that, but I'm going to LA this weekend. How about the weekend after thanksgiving?
-Ren Ching
Old November 19th, 2013, 09:20 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Potentially on the Sunday, we are starting the drive back from NH Saturday morning, so if we are back and if I have any degree of sanity left, we should be good.
Old November 19th, 2013, 10:03 AM
smob's Avatar
smob
Steve
Well, I suppose really anytime in December.. let me see what I can get off in the meantime to make it streamlined. I'll buy lunch at Atillas plus beer.
-Ren Ching
Old November 19th, 2013, 12:05 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
If you need it done earlier I should be around the weekend after turkey day
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
bolts, jump seat, mount, vin
Jump Seat Strap WestTexasDefender Wanted 5 December 9th, 2005 10:46 AM
female short seat belts for jump seats Marc Weinstein Wanted 0 March 24th, 2005 08:54 PM
Forward facing jump seat rvrsrvc For Sale - Parts 3 November 18th, 2004 08:21 PM
Removing Seat Track Bolts! JimC Defender Technical Discussions 5 November 5th, 2004 03:15 AM
beat up broken trashed jump seat dnewman9 Wanted 0 June 27th, 2004 12:38 PM
