Removing ignition switch - Defender Source
Old January 3rd, 2006, 12:41 PM
crobinson
Chris Robinson
97' D1
Anyone know how to remove the ignition switch assembly from the steering column? There seems to be a cover/cap over the bolts/screws. There has to be an easy way to remove it without drilling it out.
Chirs
Old January 3rd, 2006, 01:09 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
They are break off bolts. You tighten them until the hex head breaks off leaving what you see. You can either drill them off or use a small hammer and center punch and tap the bolts in a circle to loosen. I always use the center punch method as they are not that tight. Loosen both at the same time, though, working on each a little bit so as not to put either in a bind.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old January 3rd, 2006, 01:31 PM
crobinson
Chris Robinson
97' D1
Thanks Rob I will give it a try!
Old January 3rd, 2006, 04:01 PM
Mark M
Mark Mathews
'94 Beluga Black ST
I used a type of drill bit callled an ez-out. They did the trick with a minimal amount of hastle. When you are removing the old bolts watch for the washers. You will need them when you install the new assembly.
Old January 3rd, 2006, 06:31 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
i drilled them with a small drill then e-z outed them..
Legend in My Own Mind.
Old January 3rd, 2006, 06:33 PM
crobinson
Chris Robinson
97' D1
Thanks Mark! I just tryed to remove it with the hammer and punch but it didn't move. So a trip to Sears for bolt-out bits is in order.
switch, vin
Ignition switch jumping jellyfish Defender Technical Discussions 1 October 15th, 2009 11:50 PM
wiring of ignition switch mattdh Defender Technical Discussions 1 October 4th, 2006 01:50 PM
