Removing Gear Shift on 97 D90 - Defender Source
Old March 29th, 2009, 12:07 PM
Haston
Christopher Petite
I'm totally stumped on how to remove the t-handle from the auto trans. I have removed the handle cover, the plastic interlock thumb pin, the circlip, the 3/4" nut-- but that's as far as I have gotten and cannot see how to remove the handle from here. Any tips?
Went back for a second search using different terms and found a post by Komos, who had run into the same trouble. It appears that he arrived at the same spot as me, but his shifter handle pulled free. Mine doesn't. I feel dumb.
You would not believe how hard I had to pull up to remove the shifter-- but it eventually came free. Hope I didn't waste anyone's time with this.
Old March 29th, 2009, 02:14 PM
Please post some details, as I will need to do this soon, to clean up some wiring in both my trucks.
Old March 29th, 2009, 06:49 PM
Haston
Christopher Petite
In short: Use small screwdriver to pop the top off the shifter handle. Release flat clip to be able to slide thumb lever free (this portion of the disassembly is hard to describe, but you should see how the mechanism works one you see it). When releasing thumb lever, watch for the spring recessed in the opoosite, right hand portion of the "t". Use 3/4" socket to unscrew locking ring on shift stalk. Pull up on handle assembly to lift off the shifter stalk (thisis where I had to use a lot more force that I would have thought was necessary). Good luck.
90, 97, 97 d90, d90, vin
Removing window tops '97 D90 ST 1sttimer Defender Technical Discussions 10 September 25th, 2009 01:19 PM
I'm trying to get the automatic gear shift handle off and I need some help KeithElisa Defender Technical Discussions 4 November 30th, 2004 12:01 PM
OEM MAF sensor from '97 D90.... dmarchand For Sale - Parts 4 June 18th, 2004 06:49 AM
97 D90 maxing out at ~70mph?? vnrover Defender Technical Discussions 3 November 10th, 2003 02:14 PM
removing AC from a D90 naeirie Defender Technical Discussions 10 October 13th, 2003 08:21 AM
