Removing fender dents - Page 2 - Defender Source
Old March 12th, 2010, 11:40 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Alex, yes, I have cut the cage holes on several of the fenders... They can just make a template off of the original and transfer it to the new one. 10 min job. YOu also have to make the hole for the marker light. But that is not hard either. Just need a drill and a cutoff wheel to make both mods....
ITs one big hole for the cage..
------ Follow up post added March 12th, 2010 11:48 AM ------
Oh... I saw those pvc panels at MAR.. THey had a set at the RN booth. they looked cool. Not sure if anyone has used them yet.
Legend in My Own Mind.
Old March 12th, 2010, 02:31 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Got the right one worked out enough to attach the flare correctly which makes me happy. No more half a flare flapping in the wind, looking pretty good. Not perfect but fits in with the rest of the truck.
Thanks for the Harbor Freight referral- needed a place like that like a hole in the head. Not to mention there was a parking lot sale today
Going to order left fender, cut it, paint it, install it and then practice my metal shaping skills on that jacked up fender.
Alex
Old March 12th, 2010, 02:48 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
I did my 110 ex-mod (shit load of dents) with a regular mechanic hammer. Take your time and don't heat it (You will change the molecular of the aluminium and weaken it). Place your wings on a flat piece of wood and bang it gently until it seems right. Then take the paint out (sanding it roughly) and use small layers of putty. Putty will crack if you apply too much so try and get the worst out with the hammer. Try and sand every layer of putty to make it easier to know where to apply some more. Some people prime it, I don't.. Just apply coat over coat of paint.. Remember that Land-Rovers are tractor that goes on highways! It's not a perfect job but these dents won't be the last you'll have if you are using properly the Rover..
Old March 12th, 2010, 03:27 PM
Originally Posted by ajh View Post
There are more varieties but $90+shipping gets you something that will bounce back a bit if hit.
http://www.paddockspares.com/pp/DEFE...ir_intake.html
Rovers North is now carrying these stateside. I like the idea of the abs outer skins.
vin
Removing LH wing / Fender on '83 for bulkhead footwell repair... turbodave Defender Technical Discussions 5 May 25th, 2009 04:16 PM
removing dents from d 90 doors ttrover Defender Technical Discussions 8 February 5th, 2007 03:17 PM
D90 Passenger Front Fender (patch) ToyCrusher Wanted 4 February 25th, 2005 10:24 AM
Removing LE Checker plate - Need help removing killer adhesive JimC Defender Technical Discussions 4 December 6th, 2004 07:24 AM
