Removing Fan clutch? I have the wrench. - Defender Source
Old September 2nd, 2016, 02:31 PM
WestCoastRover's Avatar
WestCoastRover
Jeff
2000 TD5
Red face Removing Fan clutch? I have the wrench.
Trying to remove the ceased fan clutch on my TD5.
I have the correct spanner wrench for the nut. I have a strap around the plastic fins, and I'm hitting the wrench with a hammer. I can't get it loose.
Any tips?
Old September 2nd, 2016, 02:33 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Try hitting it in the different direction
Old September 2nd, 2016, 04:51 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
What Brian means is the threads tighten and loosen in the opposite direction as the conventional systems we are familiar with.
Clockwise is to loosen instead of tighten.
RDavisinVA
Old September 2nd, 2016, 05:02 PM
WestCoastRover
Jeff
2000 TD5
To clarify, on the TD5, the tread was normal. Counter clockwise removed the nut.
I also discovered a good tip: Place a 3 inch bolt between the Crankshaft pulley and one of the 3 bolt heads attached the fan shaft.
I was easily able to undo the fan clutch with my 80's Ford F-series spanner wrench.
Hope this helps someone in the future
clutch, fan, fan clutch, vin
36mm fan wrench bossman429 The Flea Market 0 September 20th, 2012 05:10 PM
Fan Clutch Wrench andyrad Defender Technical Discussions 8 April 7th, 2011 11:28 AM
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 08:10 PM
fan clutch wrench 32mm Ren Ching Defender Technical Discussions 6 July 1st, 2009 04:08 PM
Tip: 32mm fan wrench kolvedic Defender Technical Discussions 4 September 26th, 2005 07:51 PM
