Removing Door Hinges - Defender Source
Old April 2nd, 2008, 04:21 PM
everglades
Nando Zorrilla
1995/Defender
How do you remove the lower door hinge from a D90. I have new hinges painted and ready and got the door off, but no idea how to get to the back of the hinge bolts.
Are there captive nuts on the back?
Old April 2nd, 2008, 04:29 PM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
Unscrew them. Yes, there are captive nuts on the back
Old April 2nd, 2008, 04:53 PM
everglades
Nando Zorrilla
1995/Defender
Any tips or tricks? No screw on my truck has ever come off without breaking.
Old April 2nd, 2008, 05:10 PM
pmd's Avatar
pmd
Paul Dandini
None :-(
Impact Driver with the proper size screw bit.
I think it's a #4 Pozidriv
Old April 2nd, 2008, 05:17 PM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
I took the correct size screwdriver and clamped a vise grip on to it. Then I put the screwdriver in the screw and pushed in on the screw as hard as I could. Then with the vise grips, I try to rotate the screw out. It worked for me.
Good luck.
Old April 2nd, 2008, 09:11 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Good luck.
I used the same trick. Hard part was replacing the captive nuts behind (without dropping them). One's still down there somewhere...
Old April 3rd, 2008, 12:52 AM
Take the #4 posi or whatever it is and put it in a half inch air gun. Push as hard as you can and hit the trigger and pray.
Old April 3rd, 2008, 02:11 AM
minorthreat
Lance
1997 LE, 1997 Black ST
I took a small ratchet w/ a 1/4" drive and put a 1/4" socket on it. Then I put the #4 Pozi bit in there and cranked away w/out much trouble. PB blaster beforehand helped.
Old April 3rd, 2008, 06:44 AM
Bozman's Avatar
Bozman
Greg
1991 200tdi D90
I thought I was the only one.
Old April 3rd, 2008, 07:01 AM
pmd's Avatar
pmd
Paul Dandini
None :-(
If I recall, I think I tied thin string to the captive nut and was able to pull it back up when/if it fell.
When the bolt was screwed in the string was cut.
Old April 3rd, 2008, 09:08 AM
Chaucer
Will
93 110 | 97 90
Now that's smart!
Old April 3rd, 2008, 10:08 AM
cellulararrest
Chris Snyder
Mm I did that after I dropped the first one in there
Old April 3rd, 2008, 01:03 PM
RBees
Robert Bees
1994 D90 #8
Dumb question, but I thought a 'captive nut' was one that was fixed on the other side from the bolt so that it didn't fall off ? Am I missing something ?
Old April 3rd, 2008, 01:27 PM
Chaucer
Will
93 110 | 97 90
They're sometimes called caged nuts.
Old April 3rd, 2008, 11:55 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Yeah, it uses square nuts that fit inside a sort of J-nut. It basically just clips around the sheet metal of the bulkhead like a U-nut or J-nut but it holds a separate square nut rather than the bolt screwing directly into the clip.
Old April 4th, 2008, 03:17 AM
proulx70's Avatar
proulx70
Paul S.
1997 NAS BRG Soft-Top
Use PB Blaster penetrating catalyst first to soak the bolts and wait a while. Let it do the work for you. #4 pozidriv on a socket was all I needed and mine were rusted really bad.
I also have a cage nut stuck down there somewhere as well. I bought one of those magnet retractor thingies, but only after I had the hinge back on. Screw it, its there for good.
I bought the MUD UK stainless kit from EE. Any idea why they would go with different thread spacing as opposed to the original? Could have just used the cage nuts that were there anyway if they were the same.
P~
Old April 4th, 2008, 03:58 AM
When I've put stainless kits together, I've gotten 5/16" bolts because 8mm in the correct length for the doors is hard to find (costly), and I couldn't find 8mm stainless in pozidrive at all. 5/16 is within hundredths of 8mm, and the only difference is thread pitch, so if you replace both the nut and the bolt, then it works great.
If its a DIY, order both 5/16 bolts and 5/16 square nuts and just change out the nuts in the stock "j" retainers. Its better to order the ones for the door a bit long and cut them off. I also like to use nyloc nuts on the door side.
door, vin
removing steering wheel Hollywood Defender Technical Discussions 25 August 15th, 2010 03:16 PM
Removing Rear Step Bumper TurkD90 Defender Technical Discussions 16 July 20th, 2008 09:42 PM
Removing ignition switch crobinson Defender Technical Discussions 5 January 3rd, 2006 06:33 PM
Removing LE Checker plate - Need help removing killer adhesive JimC Defender Technical Discussions 4 December 6th, 2004 07:24 AM
removing weather stripping from door bottom JRowe Defender Technical Discussions 4 November 6th, 2003 01:53 PM
