Removing door card - Defender Source
Old October 7th, 2011, 08:55 PM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
Removing door card
I am interested in removing my door card so I can cut a hole for some speakers and hook the door check strap, and getting my door painted Arles Blue. I have all of the clips loose but the window winder and the push button door lock have me stumped. I tried using a trim tool but that has not worked. Any suggestions? Couldn't find a thread on this.
Old October 8th, 2011, 04:32 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I believe there are a couple of threads on this. The door lock insert (escutcheon?) pulls straight up but the door lock button remains inside. The window winder lever (or whatever it's called) is a challenge. You have to push the door card in far enough that you can see between winder lever and door card. Use Needlenose pliers to pull the circlip out. Once the circlip is out it comes off. You may need a headlamp and a healthy amount of cuss words for this part.
Old October 9th, 2011, 02:33 AM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
Thanks! I'll try that.
Old October 10th, 2011, 09:04 PM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
Manimal
Thanks for the information. Worked like a charm. Much easier with a little direction!
Old October 10th, 2011, 10:20 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Im sure the foul language helped
Old October 12th, 2011, 01:01 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I always ask stupidly obvious questions before I disassemble something. When I don't small plastic parts tend to fly all over the place.
door, vin
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 09:10 PM
Removing Rear Step Bumper TurkD90 Defender Technical Discussions 16 July 20th, 2008 09:42 PM
Removing Alpine Bar jbird Defender Technical Discussions 10 October 24th, 2007 03:59 PM
Removing LE Checker plate - Need help removing killer adhesive JimC Defender Technical Discussions 4 December 6th, 2004 07:24 AM
removing clutch place from a/c compressor Campbell Defender Technical Discussions 2 May 1st, 2004 02:58 PM
