removing clutch place from a/c compressor - Defender Source
Old May 1st, 2004, 02:18 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
Anyone have any suggestions on how to do this? I have removed the bolt holding it on. The clutch plate will not come off.
Rich
Old May 1st, 2004, 02:43 PM
Rich, I just looked at mine. There is a little bit of a dent in the end oe the bolt that you just pulled the nut off of, so my guess would be you need a puller to get the clutch off. You may also have to use a press to get it back on.
Old May 1st, 2004, 02:58 PM
Campbell's Avatar
Campbell
Rich Campbell
Thanks, maybe I will let the garage do this one. I don't want to make it worse.
Rich
ac, clutch, compressor, vin
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 09:10 PM
AC compressor clutch squeal artm Defender Technical Discussions 9 June 14th, 2010 04:34 PM
A/C compressor, hoses, and condenser for 95 D-90 727chop Wanted 0 April 8th, 2004 11:21 AM
A/C compressor is whinning Campbell Defender Technical Discussions 7 April 1st, 2004 03:59 PM
can I remove a/c compressor belt? Campbell Defender Technical Discussions 20 November 1st, 2003 10:07 AM
