removing bell housing bolts from an R380 - tips - Defender Source
Old November 4th, 2013, 10:28 AM
just got the new to me rebuildable tranny and any thoughts on removing the bell housing bolts. They seem frozen in place.
right now i am soaking with PB blaster but wow.
Any helpful hints on removal
95' D90 - daily driver..
Old November 4th, 2013, 10:32 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
Originally Posted by rlynch356 View Post
just got the new to me rebuildable tranny and any thoughts on removing the bell housing bolts. They seem frozen in place. right now i am soaking with PB blaster but wow. Any helpful hints on removal
breaker bar and jack handle for leverage. Worse that will happen is that you shear the head off. Then you can drill and tap. Also try tightening them a little to help break any thread lock.
Old November 4th, 2013, 10:34 AM
They are loctite'd in. Those bolts have a nasty habit of backing out and once loose in the bell housing destroying the clutch assemble/pressure plate. Be sure to use loctite when re-installing.
Old November 4th, 2013, 11:21 AM
cool thanks - loctite is what i was wondering
i assume Red Loctite? which means i can hit it with some heat as well if needed.
Old November 5th, 2013, 07:32 AM
all came out intact... No Loctite on any of them which i assume was from the factory this way.
Old November 5th, 2013, 08:41 AM
Not sure what they use but its usually a light tan color. No need for the red- blue is fine on re-assembly.
Old November 5th, 2013, 05:37 PM
The bolts we're clean and nothing used on any of them, I use the blue stuff on reassembly
Old November 5th, 2013, 07:15 PM
When I do this I use a half inch impact gun with an extension. They came right out.
Old November 5th, 2013, 07:58 PM
me too
bolts, r380, vin
Defender V8 R380 Bell Housing RoversNorth The Vendors Loft 6 September 30th, 2013 11:50 AM
V8 R380 Bell Housing JPRO576 For Sale - Parts 0 August 27th, 2013 10:41 AM
Loose bell housing bolts rattling around inside... rdavisinva Defender Technical Discussions 2 February 19th, 2013 08:34 AM
300 TDI R380 Shifter / Bell Housing SafariHP The Vendors Loft 0 October 1st, 2008 07:24 AM
WTB: Bell Housing for R380 NashvilleRover Wanted 9 August 17th, 2008 07:32 PM
