Removing aux heater core - Defender Source
Old March 11th, 2007, 08:29 PM
cpk
Corey K-nig
1993 NAS Defender 110
The heater core in the aux heater started to leak. This is the heater in the passenger side seat box. Don't know much about it. I have a 93 NAS 110 and I think this was a dealer installed option or a factory option. Anyway, I see three bolts sticking through the seat box side from underneath where the heater is and removed the nuts, but it is still in there real tight. When I yank on it it doesn't budge. Any idea on how to get it out or what I'm missing?
Old March 11th, 2007, 11:07 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Can you post a picture?
JP
legend in my own mind
Old March 11th, 2007, 11:49 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Never seen it, and I've got a 110! I have to say that it sounds like you're missing something though. In all my experience working on cars I have found that once all the bolts are off it rarely takes much effort to remove something. Usually if I start to pry or pound on something I stop myself and take another look. More often than not I have missed some hidden bolt, clip or screw so I would take another close look.
Old March 14th, 2007, 09:35 PM
cpk
Corey K-nig
Finally got a picture. Check the link below. It is a picture of the unit in the seat box. It is tight in the seat box, so there has to be a way to get the whole thing out for maintenance. I was hoping someone has dealt with this issue before I dismantel more than is necessary.
Old March 14th, 2007, 09:42 PM
mattdh's Avatar
mattdh
Matt Hurst
any on the trans tunnel side underneath?
Old March 14th, 2007, 09:57 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
That is really interesting... I have never sceen one before
Old March 15th, 2007, 08:46 PM
cpk
Corey K-nig
There are three studs coming from the seat box into the transmission tunnel. They have to connect to the heater. I removed the nuts and washers, and it's like I did nothing. I thought this thing was fairly common, but it doesn't look like it.
Old March 16th, 2007, 09:23 AM
You could just disconnect the coolant lines and leave it in there for the time being.
Old March 16th, 2007, 09:31 PM
cpk
Corey K-nig
That's what I'm doing for now, and it's fine. The extra heater comes in handy, though when the temp is low.
Old March 18th, 2007, 07:34 PM
andyrad
Andy Radlgruber
None.
I was actually thinking fo removing mine and replacing it with a Mojave heater from Flex-a-Lite All the wiring is there and so are the coolant lines, in and out. It could be a straight swap and by the specs of the Mojave, a lot more heat. I find my aux heater is a waste of an on off switch.
Some people are so heavenly minded that they are NO EARTHLY GOOD!
heater, vin
NAS D110 Heater Core Removal Jon_Winningham Defender Technical Discussions 6 January 8th, 2014 11:23 PM
Aux Heater? NASD90 Defender Technical Discussions 59 December 21st, 2010 12:24 PM
WTB/WTT: for 87 RR heater core headdamage Wanted 2 November 17th, 2005 06:14 PM
Heater core ?? & FYI D90user Defender Technical Discussions 4 October 14th, 2005 03:27 PM
Heater core Burke Wanted 1 December 9th, 2004 12:21 AM
