Removing Alpine Bar - Defender Source
Old May 13th, 2004, 06:07 PM
jbird
Justin Bird
94 D-90 ST
Removing Alpine Bar
Can someone please explain to me how to remove my Alpine bar. The one currently on my D90 is damaged and I am going to replace it with a new one (a new one came with my car when I purchased it), but the problem is that I have not been able to remove the current bar. Any help would be greatly appreciated.
Old May 13th, 2004, 06:35 PM
Remind me whats the alpine bar? Is it the one in the back that lifts up to come out (no bolts) or the one that goes across the top of the windshield that has 4 bolts holding it in from the bottom that you can get to by removing the visor bolts?
Old May 13th, 2004, 06:37 PM
jbird
Justin Bird
94 D-90 ST
It is the one in the back that does not seem to have any bolts holding it in.
Old May 13th, 2004, 07:17 PM
howellm70
Michael Howell
It should just pull right out....give it a good yank with hands on either end of the bar.
White '95 D90 ST
BRG '92 RRC LSE
Black '02 RR HSE
Old May 13th, 2004, 08:13 PM
Trevor Tarr's Avatar
Trevor Tarr
Trevor Tarr
1997 D-90 4.6 NAS ST
I've always had trouble getting mine out. One trick seems to be pushing down in the middle of the bar while pushing up on the ends. Three arms would be handy....
Old May 13th, 2004, 09:08 PM
Mine pops right out, try a dead blow hammer.
Old May 13th, 2004, 10:26 PM
WCURoverD90's Avatar
WCURoverD90
Jason Habbal
1997 Defender 90 #1104
Mine comes out with a rubber mallet...just takes a good hit once and pops right out.....
"tell them to phucough"
Land Rover-The Best 4x4xFar
Old October 23rd, 2007, 03:58 PM
kiphartzell's Avatar
kiphartzell
Kip Hartzell
'95 4.2L NAS D90
Resurrecting and old post.....
My '95 D90 ST has had a Badger half-cab installed on it for a number of years and has been in quite a bit of rain. The last time I tried to remove the alpine bar it was completely seized (ugh, rusted!?!) even with some significant persuasion from a rubber mallet.... I tried some penetrating spray (over several days), but could not get the ends to pop out. Since heat is not a good option for the surrounding rubber, any suggestions to getting the studs out of the cantrails?
Old October 23rd, 2007, 05:57 PM
drill out the rivits and then get a pipe wrench on the plug.
Old October 24th, 2007, 11:54 AM
kiphartzell
Kip Hartzell
'95 4.2L NAS D90
Good idea.... I tried something similar to this: I drilled out the rivets and put a hardened steel bar through the rivet hole to remove the stud..... Neither stud budged with both a twisting force or upward force. I was reluctant to use a pipe wrench since it would munge the remaining studs. I still need to use the alpine bar with my surrey top and now use s/s bolts to re-attach the bar itself, when needed.
Old October 24th, 2007, 03:59 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I used a Big F*&^^ Hammer
Legend in My Own Mind.
vin
New Alpine bar question... DonFromWhitby Defender Technical Discussions 11 May 21st, 2009 12:33 PM
alpine bar (soft-top piece) d90boy Wanted 2 December 3rd, 2008 05:27 PM
Alpine bar and one attachment for alpine bar evilfij Wanted 0 June 14th, 2006 09:41 AM
Alpine Bar surfd90 Wanted 1 July 7th, 2005 02:50 PM
WTB: Alpine bar for '94 D90 ST cgalpin Wanted 6 September 9th, 2004 08:51 AM
