Removing a stuck injector - Defender Source
Old January 18th, 2016, 05:24 PM
300 tdi head has a stuck injector. I assume it is corroded so bad it's locked in there. Any suggestions how to get it out? Thinking that I'll drizzle some lye or phosphoric acid on it to dissolve the corrosion.
Old January 18th, 2016, 05:45 PM
GM13's Avatar
GM13
Gene
'83 110 CSW
Pb blaster soak and a big wrench to work it back and forth a bit? They are fairly stout. If that fails move to slide hammer?
Old January 18th, 2016, 05:48 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Mine let loose when I ran the truck with the clamps loose(by accident)
Before that I couldn't get them loose to save my life.
Better with a warm head/engine as the aluminum expands away from the injector. An, yes, turn with a big wrench on the flats to work loose.
Old January 18th, 2016, 06:11 PM
Whiesel's Avatar
Whiesel
Eric Williamson
LR-90 300 tdi
A slide hammer is the correct way. Assuming you don't have one maybe fashion one but you will need something to screw onto the end of the body.
Look what I found when I took my injectors out.....
------ Follow up post added January 18th, 2016 04:15 PM ------
With pic...
Old January 18th, 2016, 06:19 PM
Whiesel's Avatar
Whiesel
Eric Williamson
LR-90 300 tdi
Eventually...
Old January 18th, 2016, 06:22 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
X2 on the slide hammer. I had one stuck so badly that it actually cracked while I was turning it back and forth with a wrench. You can rent one cheap from Advance, then just tack a couple of nuts together to thread into the shank of the slide hammer and into the head of the injector. It's a 14mm nut but I can't recall the pitch off hand.
-Ash
Geared Restoration Co.
352-572-3236
Old January 18th, 2016, 06:44 PM
Slide hammer is a great idea!!! I have plenty of nuts I can cut off old fuel lines!!! Thanks d90!!!!
Old January 18th, 2016, 07:06 PM
turn the injector clockwise-ie like you would tighten a bolt. The injectors screw apart in the middle and I had one come apart and it ruined the injector
Old January 18th, 2016, 07:09 PM
Yeh right now it is so tight it bent an open end wrench that had a pipe on it
Old January 18th, 2016, 07:15 PM
#4 ?
We were using acetylene and alternatively spraying kroil.
Old January 18th, 2016, 08:30 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
What's a pro tip to keep them from getting stuck? Anti-seize when reinstalling?
Old January 18th, 2016, 08:38 PM
I would not put anything in there. They most likely get stuck after leaking which fills the void with carbon. Without a leak the area should always be clean.
Removing Faulty Ignition Switch - It's STUCK rijosho Defender Technical Discussions 20 March 29th, 2017 12:54 PM
3.9 injector size boxerhips Defender Technical Discussions 13 March 14th, 2006 06:15 PM
Throttle Body Injector (TBI) for 3.5 V8 gregorw47 Defender Technical Discussions 9 January 8th, 2006 12:55 PM
Fuel INjector "plug" rover4x4 Defender Technical Discussions 5 November 30th, 2005 10:30 PM
Removing LE Checker plate - Need help removing killer adhesive JimC Defender Technical Discussions 4 December 6th, 2004 07:24 AM
