Removing 200tdi engine - remove lt77/lt230 also? - Defender Source
Old January 7th, 2013, 03:08 PM
Hey folks, well, it's time to lift the engine off the frame and set it down for a few days.
1. When I lift the engine out of the truck, is it ok to simply unbolt the driveshafts, and lift the engine, LT77, and LT230 altogether? Or should I remove the LT77/LT230 combo first, then the 200tdi engine? All this assuming that I have rigged properly and leveled the load with chains.
2. Is it ok to just rest the engine/transmission/transfer case on the oil pan temporarily? I've done this with other (smaller) engines but never with the 200tdi.
Old January 7th, 2013, 03:21 PM
Abrooks's Avatar
Abrooks
Tony Brooks
If you did split them it seems like it'd be a good opportunity to put in a new clutch and TO bearing.
Old January 7th, 2013, 03:27 PM
Good point Tony. I've sent Mike an email asking how old the clutch is. Any ideas on the cheapest place to buy a kit online?
Old January 7th, 2013, 03:55 PM
No matter what, replace the clutch fork with a reinforced one....
Old January 7th, 2013, 05:46 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Center of gravity is pretty far back when your dealing with engine/tranny/transfer combo and I find it easier to remove engine by itself. Cuts down on the number of beers you have to buy since you probably can do it by yourself. Putting it back in - maybe one buddy.
____________________
Chris Hinkle
Current project - D110 with extended cab and LS3
Old January 7th, 2013, 09:01 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I did it in one chunk with bulkhead and everything in place.
200tdi, engine, lt230, tdi, vin
200tdi or 300tdi Engine Cover bitz Wanted 47 July 31st, 2017 02:19 PM
200tdi defender rebuilt engine for sale Apocalypse Vehicle For Sale - Parts 5 November 6th, 2012 12:48 AM
???still can't get the trany unbolted from the engine???? kit Defender Technical Discussions 4 October 23rd, 2003 03:20 PM
Why can't I disconect the engine from the trany? kit Defender Technical Discussions 6 October 22nd, 2003 07:40 PM
