Remove Front Shocks/Towers? - Defender Source
Old August 27th, 2015, 04:43 PM
RBBailey
RBBailey
1965 IIa
I have the type with studs at both ends. The nuts are rusted, and want to strip. When I do turn the top nut, the whole upper half of the shock turns with it, so....
I'm thinking I need to do some cutting, but I'm not sure where. And once I get the towers off, I'll have to pull the shock... hummmmm....
Project:
1965 IIa SWB
Old August 27th, 2015, 04:46 PM
Do you have a pipe strap wrench or a set of big ass channel locks to grab it with? You can also split the nut with a grinder and a cutting wheel and pull the whole thing out.
Old August 27th, 2015, 05:00 PM
RBBailey
RBBailey
1965 IIa
I hope the rust on the tower isn't so bad I can't blast it and refinish.
Cutting the top nuts should be easy. Not sure how to get in to the bottom nut if I'm going to pull the whole thing out. Even if I did have the right wrench, I'm sure I would not be able to turn it.
Project:
1965 IIa SWB
Old August 27th, 2015, 05:03 PM
It's a bit messy but you can also cut the bottom off of the shock and then cut away at what is left or you can hit the bottom nut with a torch (smoke wrench) and it will hopefully twist off afterwards.
Old August 27th, 2015, 05:54 PM
The Dro
Dro
1988 Ninety
I've used a Sawzall cutting through the bushing.
Old August 27th, 2015, 05:59 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
And use this... Very helpful
http://www.amazon.com/gp/aw/d/B00004...CVNNHW7SMQ8Y65
Old August 27th, 2015, 06:11 PM
cbfritz_03
Carmen
none
I'm getting ready to do mine this weekend on the 95 lwb....never done them before, I hope it goes well ...oooh boy
Old August 27th, 2015, 06:16 PM
RBBailey
RBBailey
1965 IIa
The process of changing springs and shocks is actually not hard if you set yourself up well, get the spring compressor on correctly, and if the rust isn't as horrible as mine!
With the rust, I'm just at a dead end right now. Cutting is only option.
Project:
1965 IIa SWB
Old August 27th, 2015, 06:55 PM
cbfritz_03
Carmen
none
That's exactly what I'm telling myself. 'eh, easy peasy.' oooh and I understand the frustration of having to break out the cutting tools...blah! Grimy sweaty time.. Good luck to us both Mr. Bailey
Old August 27th, 2015, 07:11 PM
Put a wrench on the bottom nut and turn with shock with pipe wrench.
I'm pretty sure I got a ratcheting wrench on mine after a few turns and then it came of quickly.
Old August 27th, 2015, 07:18 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
-Get a smaller pipe wrench, don't mess with a strap one.
-Grab the lower part of the shock with the pipe wrench and remove the lower nut.
-Remove the 4 shock tower retaining nuts.
-Pull the tower and shock out together.
-You should now be able to grab the upper part of the shock with the pipe wrench and remove the upper nut.
-If you have the plastic shroud on the upper part you can cut it with a knife, peel it back, and stick the pipe wrench on the shock shaft.
-Use an impact on the upper nut if you can.
* I have some D1, D2, and RRC external towers for sale if you're interested.
4 Bilstien Resovoir shocks with towers ron For Sale - Parts 23 January 23rd, 2012 04:45 PM
Koni Heavy Track Shocks +2 - Land Rover - 4 New Shocks JohnC The Vendors Loft 7 April 13th, 2010 09:34 AM
How to remove channel to remove seat skins Campbell Defender Technical Discussions 2 October 23rd, 2009 05:47 PM
what tool needed to remove shocks? ditskovich Defender Technical Discussions 10 May 13th, 2009 03:36 PM
remove front diff? scoloco Defender Technical Discussions 31 April 7th, 2005 03:23 AM
