remove front diff? - Defender Source
Old March 28th, 2005, 01:16 PM
scoloco's Avatar
scoloco
'94 D90 ST
remove front diff?
Whats the easiest way to remove the front diff?
I've been told two ways.
1. remove the hubs, pull axle out.
2. remove the entire swivel assembly, pull axle out.
Which is the better way to go? Or is there another way better still?
Downsides?
tnx
-scott
'94
Old March 28th, 2005, 04:56 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
It is quicker to remove the hubs, spindles then just pull the axles out. I did it with no problems. The swivel housing bolts to the axle tube suck to remove and you have to do them with an open end wrench. It takes forever.
Legend in My Own Mind.
Old March 28th, 2005, 09:10 PM
If you have a BFH and a 14mm gearwrench and are STRONG I would do the swivels.
Old March 29th, 2005, 06:21 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
If you don't need to strip dow the swivels I'd undo the 7 bolts that hold the swivel on'you can even get away without draining the brakes down. nyou do need to hve eaten at least 3 shedded wheats for breakfast because tje swivel assembly is a bit heavy and rather difficult to manage
Mike Hammond
Old April 1st, 2005, 09:22 AM
scoloco's Avatar
scoloco
'94 D90 ST
If I remove the swivels, I'll probably have to undo the brake lines, and deal with hook up and bleeding them. Right?
OTOH going the other way, I'd need to acquire one of them special sockets for the hub bolt, and make sure I dont over/under tighten that bolt when reassembling. But I get to check/repack the bearings this way.
Hmmmm...
Old April 1st, 2005, 09:43 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
remove the calipers & use a coat hanger & hang them from the shock tower!! Don't remove the line.
Scott Jimmy and I both have the socket. And you really don't need a Torc wrench, you just have to kinda feel it out, thats how I do mine and my truck has never lost a wheel or burnt out the bearings.
Old April 1st, 2005, 05:28 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Unhappy [cough!]
Having lost a wheel while driving in town 2 weeks ago I decided it was time for a torque wrench instead!
(123euros...geeeeez!)
Hey,is this about removing diff or swivel housing?
I'm interested in both but swivel has priority at the mo (need to change the seal).
I will happily take note of any clever suggestion and tip to make job easier
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old April 1st, 2005, 06:59 PM
Hmmmm...
Both methods require you to remove the brake calipers. As stated, just un-bolt calipers (two bolts) and hang out of the way while leaving hoses attached. The caliper bolts should be torqued properly. They are meant to be quite tight.
Old April 2nd, 2005, 07:03 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Post
Hi John,
calipers will not be the major issue I think
I'm spreading on different forums
you see!
2 weeks to have the EP00 for swivel housings...sob...I'm waiting still,nothing until Monday...
Michele
D90 VNTdi
[O]===[O]
Old April 2nd, 2005, 11:27 AM
scoloco's Avatar
scoloco
'94 D90 ST
Yeah, but you have to know what you are feeling for. If you never done it - its kinda difficult.
Old April 2nd, 2005, 03:20 PM
At the swivel you do not have to touch the brakes.
Old April 2nd, 2005, 05:31 PM
stevewhitaker's Avatar
stevewhitaker
Stephen Whitaker
1994 D-90
I agree about not having to do anything to the brake lines or brakes if you unbolt the enitre swivel pin assembly at the flange. After unbolting, pull the entire assembly out a bit so the axle ends clear the differential, and have at it. Have a support handy on which you can set the rather awkward swivel pin/brake/hub assembly so you don't strain your brake lines. I just replaced my front differential with an airlocker using that method and had absolutely no problems. Enjoy.
Old April 2nd, 2005, 05:37 PM
Scott when do you plan on doing this?
Old April 3rd, 2005, 09:26 AM
scoloco's Avatar
scoloco
'94 D90 ST
Yesteday. But it was raining and I decided I had had enough water dripping onto my face after getting the rear drive shaft hooked up and a couple bolts for front and the skid plate undone (need to figure out how to get a couple buggered bolts dealt with too). No garage this time.
Since I'm now jobless with nothing to do during the week, was going to probably attack this on Monday. But, I'm open to suggestions...
Old April 3rd, 2005, 09:56 AM
The buggered bolts are a pain, I normally try and hammer a socket on them but you know this, vise grips, and maybe some penatrating oil to help. I was just wondering as we are getting close to hour zero before the big trip. I was goning to say I could help today but I just saw I need to do a bit more work on mine before I can call it a weekend.
Old April 3rd, 2005, 11:23 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I still think its alot quicker removing the rotors and spindles. All the bolts can be done with a rachet or air tools and it goes quick. WIth air tools, I had one side un done with the axle pulled in 20 min. It was like a NASCAR pit stop. lol
Old April 3rd, 2005, 12:40 PM
scoloco's Avatar
scoloco
'94 D90 ST
Minor clarification. The buggered bolts hold the skid plate up. Need to get that out of the way before the diff will come out easily. I was still underneath the the truck (with water dripping in my face). Havent gotten to the the wheels yet.
Mike, you offering your wiz bang socket for me to borrow? Thanks for the offer to help get me going, but it looks like yous got some work ahead of you still. Or you may be riding passenger again.
Old April 4th, 2005, 08:56 AM
scoloco's Avatar
scoloco
'94 D90 ST
Going via the hubs, do I need some replacement lock washers that lock the hub bolts?
Old April 4th, 2005, 09:02 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
best to change them scott,northeast british parts just up the road in concord about a $1 each
Front Diff Vibrations 1of40 Defender Technical Discussions 3 February 6th, 2008 10:41 PM
Front diff: no oil! BarryO Defender Technical Discussions 5 May 15th, 2006 04:35 PM
Fiberglass Hard Top, Fan Clutch and Front QT Diff Guard cgalpin For Sale - Parts 10 January 6th, 2006 10:45 PM
QT Front Diff Guard d901560 Wanted 1 August 9th, 2005 11:45 AM
