remove flex fan - Defender Source
Old October 12th, 2005, 09:13 PM
scoloco's Avatar
scoloco
'94 D90 ST
remove flex fan
I'm trying to remove my flex fan for an electric fan install. Problem is I cant get the *&% thing off. So far I've removed the radiator (and a whole bunch of other stuff to get to it) to get better access. I've busted the fanbelt in trying to use that to hold the pulley as I try to undo the nut. I need a method of holding the pulley/waterpump while I loosen the nut (reverse thread, I think I have that right). I dont have a whole lot in the way of tools though. Once done with this, I'll be able to get going again.
Right now I'm at a loss as to how to proceed to get it off. Any ideas?
Old October 12th, 2005, 09:29 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I use a bike wrench 32 mm as it is thin & give it a sharp rap with a dead blow hammer.
Old October 12th, 2005, 09:35 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
a sharp rap with a hammer and screwdriver
3rd low and BOOT IT
Old October 12th, 2005, 10:38 PM
scoloco's Avatar
scoloco
'94 D90 ST
Tried that. Didnt work. Course I cant find my BFS so I had to resort to a standard (not big) screwdriver.
Old October 12th, 2005, 10:55 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
You know, I can't remember if it's the V-belts or the serpentines..... (funny, since I did the same thing myself) but one of them is reversed threads. I know I was bashing mine all afternoon before I realized that.
-Hans
My oil line fix
My 100k stopped odometer fix
Old October 12th, 2005, 11:16 PM
Hey I know someone local to you who has some tools and a Rover that runs, maybe he can swing by and give ya a hand?
Old October 12th, 2005, 11:35 PM
94 should be a reverse threaded V-belt from what I remember.
Old October 13th, 2005, 08:28 AM
scoloco's Avatar
scoloco
'94 D90 ST
Yah, I think I'm ready.
Its a '94 - v-belt. The 4.0 in the '97s introduced the serpentine belts.
Old October 13th, 2005, 02:02 PM
johnlee
John Lee
Scott,
I don't know if you want to take your tool kit this far, but this is what we use at the shop:
http://www.lislecorp.com/tool_detail.cfm?detail=751
You attach the appropriate sized wrench to your fan clutch, then attach the rod to the wrench, and then attach the rod your pneumatic hammer. The smallest burst will shock loose the nut and your fan clutch will come off very easily. This arrangement is expensive and complicated, but it works beautifully as the impacts from the pneumatic hammer will easily shock loose the fan clutch nut without having to hold the fan clutch stationary.
Another method is to use the appropriate sized wrench and then hit it with a hammer to try to shock loose the fan clutch nut.
My 97 has a 36mm nut. I'm not sure if the 94's and 95's are different. I don't think they are though.
Old October 13th, 2005, 10:28 PM
scoloco's Avatar
scoloco
'94 D90 ST
Thanks for the above sets of suggestions. I got some help with some better tools and we managed to shock it enough to come off. And for the record - yes - its reverse thread.
fan, flex
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 01:49 AM
Flex Fan (Clutchless Fan) NashvilleRedD90 Defender Technical Discussions 3 June 12th, 2005 03:09 PM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 06:19 AM
Flex Fan for a 90 BrknRvr Defender Technical Discussions 9 September 20th, 2004 08:37 PM
