Remove filler restrictor on fuel tank.. - Defender Source
Old September 7th, 2010, 02:53 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
How does this come out? Is this welded in? The metal restrictor and spring-loaded flap prevent the accidental filling of diesel fuel - I recently converted to diesel and will have to carry a funnel to the filling station until I get this restrictor removed or change out the filler neck completely...
Old September 7th, 2010, 03:13 PM
Mike at ECR said it can be desoldered I believe.
Old September 7th, 2010, 03:55 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I cut mine out with a hole saw, 1-1/2"....I think. Of course you'll have to remove the hose to prevent the shavings from ending up in the tank.
Old September 7th, 2010, 04:16 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Jason, I have a loose filler neck out in the garage that I just went and looked at. The restrictor (oval shape) is female and looks to be press fit onto a male piece of the filler neck. I can't tell if its welded but you can feel that it is two pieces by removing the gas cap and running your finger inside.
Old September 7th, 2010, 04:28 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Yup, thats how we do it.
Email:
Old September 7th, 2010, 04:39 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
So, a blow torch and some pliers ought to do it? Assuming it's removed from the truck of course :-)
fuel, fuel tank
I am dropping the fuel tank and I have a couple of questions, help QUEST Defender Technical Discussions 24 September 26th, 2009 03:26 AM
Leaky Fuel Tank cbass Defender Technical Discussions 12 June 2nd, 2005 04:50 PM
Adding a Side Tank - Alternate Filler Method JimC Misc. Chit-Chat 6 October 25th, 2004 12:29 PM
Air filters and a bad fuel tank valve thingy! RickM Defender Technical Discussions 1 August 9th, 2004 03:29 PM
