Removal of seat rails from frame? - Defender Source
Old May 1st, 2006, 10:39 AM
mgrgpg
Mark
1989 D110
Having no luck trying to pull the seat rails, (the ones that bolt to the seat box) from the frames. I want to strip and paint the frame in pieces. There seems to be a ball bearing in there to stop it from sliding off. Any suggestions from those who have pulled them out.
Mark
Old May 1st, 2006, 11:02 AM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
mark, you need to remove the entire mount. There are 4 bolts at each corner that hold the seat and slide mount to the seat box, and lift the whole assembly out.
Chris von C
[/size]
Old May 1st, 2006, 11:17 AM
mgrgpg
Mark
1989 D110
I have the entire assembly removed from the truck - trying to pull the rails out from the frame itself.
Old May 1st, 2006, 12:54 PM
They arent removeable, the stops are pressed in.
Old May 2nd, 2006, 09:42 AM
mgrgpg
Mark
1989 D110
That is what I thought but was hoping I missed something.
Mark
Old July 13th, 2013, 04:58 PM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
I thought I would piggy back on this thread. I am replacing the MOD seats in my truck with a set from of full seats from a 97 NAS. The replacement seats are complete with adjusting rails, etc.
I pulled the 4 bolts which hold the MOD seat frame to the adjusting brackets, but the adjusting brackets holes dont line up with the NAS seat holes (there is 1 bolt hole on the NAS seats).
It appears I need to pull the adjusting brackets all together and drill a single new hole at each corner for the NAS seats. Just making sure Im on track.
J
Old July 13th, 2013, 08:48 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
The older seat has two bolts in each corner while the newer seats only use one. If you take the seat frame off of the seat slider you can just swap them over so that you can use the two hole set up. Of course if the older seat sliders are in good condition. The Philips head screws are hard to get loose, I had to use a impact driver to loosen them. On two I had to drill the head off. I just did it on a set of seats and it isn't too hard to do.
Old July 13th, 2013, 09:26 PM
josh-man's Avatar
josh-man
joshua
Thanks, Capt. I pulled all 8 of the passenger seat flat heads and will head to Home Depot for 4 bolts. The new seat frames and sliders are in great shape compared to the MOD ones..
Any advice on grade of bolts? Also thinking a big washer and lock nut to spread some of the force could be useful.
Thanks again!
Old July 13th, 2013, 10:17 PM
Capt Milks's Avatar
Capt Milks
I would use grade 8, 8.8 or 10
Old July 14th, 2013, 09:21 AM
josh-man's Avatar
josh-man
joshua
Thx!
Old July 14th, 2013, 09:58 AM
josh-man's Avatar
josh-man
joshua
Perfect thx Capt
Old July 22nd, 2013, 04:05 PM
josh-man's Avatar
josh-man
joshua
Originally Posted by josh-man View Post
Perfect thx Capt
This is a worth while upgrade. So much more comfortable and safer but most important these seats sit up higher to clear the lip and slide all the way back giving my 6'2" legs probably 4-6" of additional leg room! Unexpected bonus.
Old July 22nd, 2013, 04:06 PM
josh-man's Avatar
josh-man
joshua
Better pic
Old July 22nd, 2013, 06:00 PM
Capt Milks's Avatar
Capt Milks
Yep those look like the standard seats. The make extended slides but the rear bulkhead and lip may be an issue unless you do something to raise the track. A couple vendors sell the extended sliders.
Old July 22nd, 2013, 08:29 PM
josh-man's Avatar
josh-man
joshua
I was thinking about those higher rails, but these got me up over that lip which is all I needed to do so they now slide back over that lip. Now if I did the bulkhead removal, I'd definitely get them so I could push further back and tilt back more too!
Baby Car Seat QUESTION Flagg Misc. Chit-Chat 5 August 4th, 2007 06:39 PM
Front Seat Covers Flagg Defender Technical Discussions 8 February 13th, 2006 07:45 AM
Rear Bench Seat + hardware Chaucer For Sale - Parts 8 September 29th, 2005 12:16 AM
looking for seat frame jcasteel Wanted 0 July 19th, 2005 09:55 AM
Which seat rails to get? jam90 Defender Technical Discussions 4 June 20th, 2005 11:04 PM
