Removal of plastic air intake / wing / inner fender - Defender Source
Old December 8th, 2012, 08:01 PM
Ok so I'm probably going to ultimately remove the entire wing, but right now I'm focused more on getting the galvy inner fender out. In order to get to the top bolts that hold the inner fender on I need to remove the plastic air intake shown here.
How the heck do you get this thing out? Been wrastling with it for a bit now...
Old December 8th, 2012, 08:25 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
It is a bit fiddly but with a little care it can be removed. I pressed down on the plastic intake to get the front part out and then wedged the rear out. The front collapses pretty easy but the rear is a bit more solid.
Land Rover 110
Old December 8th, 2012, 09:11 PM
I had a dog and Bingo was his name-o....worked like a charm, thanks Mike. I took a 2x4 and used it to hammer out the front of the intake...same theory based on what you said.
Old December 9th, 2012, 09:43 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Between using 2x4s and 7lb hammers, I'm tempted to swing by just to see what the rest of your toolbox looks like...
MonLand
1995 D90 NAS
1996 Discovery NAS
Old December 9th, 2012, 09:49 AM
Aren't tools for bashing stuff? We can't all just use micrometers!
air intake, wing
In line blower for mantec raised air intake system LenB Smaller Projects 22 November 20th, 2009 08:24 PM
air intake hose?? / source for cheap switches NASD90 Defender Technical Discussions 15 July 6th, 2005 02:40 PM
Wing top Air Intake or Scoop??? adibitar Defender Technical Discussions 7 July 8th, 2004 08:57 AM
