remote winch throttle cable-suggestions & pics - Defender Source
Old March 12th, 2011, 09:37 AM
PMKColorado's Avatar
PMKColorado
Paul Koentges
'95 White D-90, #2625
Suggestions for remote idle speed control, safe...something that won't possibly jamb open or interfere with normal throttle operation…even thinking about a quick-disconnect for on/off road, though I wouldn’t be happy stuck at 2800 RPM, low range with about 1000’ drop to my left…
Old March 12th, 2011, 10:51 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
EE used to sell a great Genuine Parts one but I can't find it on their site. I'll look around for one. It installed on the right side of the steering column.
------ Follow up post added March 12th, 2011 08:53 AM ------
http://www.roversnorth.com/store/p-5...der-90110.aspx
Old March 12th, 2011, 06:53 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Sounds like you want a vernier throttle control:
http://www.eriksmilitarysurplus.com/thcoca10ftwi.html
Some have a button in the center that you push that releases it to return to idle. Not sure if the one above does.
My '62 has a factory hand throttle that is a lever you slide over that catches in notches.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old March 12th, 2011, 07:01 PM
PMKColorado
Paul Koentges
found parts--- from the dark side...
http://www.4x4xplor.com/handthrottle.html
looks like there are several hand throttle options out there...thanks
DIY- http://www.stu-offroad.com/engine/th...p_throttle.htm
Better ones come with on-board welders...
Old March 13th, 2011, 06:00 PM
carlosz's Avatar
carlosz
Carlos
what about using an electric vacuum solenoid with a vacuum menbrane as those on japanese cars, the default is idle but if you wire the solenoid to a toggle switch all you have to do is flip a toggle switch.
upon installation you set the desired off idle rpm.
hooh up is simple, plug one end to vacuum the other to membrane vacuum is applied to membrane upon actuation of electrical solenoid.. all of thes can be found ala junkyard for a couple of buck.
the membrane could be a cruise control membrane with slack to desired rpm.
that way you know if you are in a rush you simply flip the toggle with pre set rpm and you dont run the risk to over rev the engine since default is idle.
Old March 14th, 2011, 11:34 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I actually picked up one of the Rubicon Express kits a few years back and was planning to install it on my '69 Bronco...the Bronco was sold before I installed it so now plan to try fitting it to the NAS. Plan is tackle this one in the next month or two and will let you know how it goes.
Old March 14th, 2011, 11:39 AM
PMKColorado
Paul Koentges
I like the military rachet handle...looks a bit more stock...source for buying? I am thinking about mounting it on the lower dash, next to the steering column.
Old March 14th, 2011, 02:45 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Ive got a NOS military ratcheting T handle. It was used on alot of different trucks, an M38A1 being one of them.
Those work well. Had one on my deuce and when running the PTO winch it came in handy. A quick twist would let it move back to idle.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old March 14th, 2011, 03:47 PM
Rugbier's Avatar
Rugbier
Gustavo
Carlos any existing one like this?
NO SIGNATURE
Old March 14th, 2011, 04:04 PM
I would use the "quandret" style one found on 2.5NA military trucks. It is similar in design to the series hand throttle but designed to work with a cable throttle body. It has a lever with notches to control the throttle. I have one somewhere in my attic as it came off a truck with a capstan PTO (no, I can't sell it, but I am sure you can find another one).
Ron
Old March 15th, 2011, 04:24 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Ron
I like Antichrist's vernier cable, but for OEM, this is the V8 cable: Cable
And this is the bracket that goes under the dash Bracket
There's also a cover for the interior bracket, a firewall grommet, and a bracket that connects the cable to the throttle linkage on the engine. I'm too lazy to look up part numbers, but it's all in the RAVE.
This original cable will release when you step on the go pedal. I have the equivalent diesel version in my 110. Actually I've not yet figured out what the difference is, even though there are different part numbers. Might just be the length of the cable sleeve, since the diesel one has a short run to the IP.
Tony
1984 110 "Smokey" (sold)
Old March 15th, 2011, 08:23 AM
PMKColorado
Paul Koentges
thanks...great help. I'll post pictures when/if I get it installed.
Old March 16th, 2011, 09:13 AM
PMKColorado
Paul Koentges
http://www.xtremeterrain.com/throttl...-71jeepcj.aspx
found some round Knob in black...problem may be the 36" lenght cable, but I think I can modify..
remote, winch
?????? jimmy salmon Defender Technical Discussions 8 October 13th, 2005 11:54 AM
winch cable jimmy salmon For Sale - Parts 3 July 24th, 2005 09:35 PM
winch cable jimmy salmon For Sale - Parts 0 June 3rd, 2005 07:20 AM
WARN 8274-50 Winch, THE ULTIMATE!!! RedRhinoProducts For Sale - Parts 0 September 28th, 2004 08:18 AM
'93 Defender 110 Winch Remote ember Wanted 3 March 28th, 2004 02:45 PM
