Remote reservoir Saginaw pump on 200 Tdi? - Defender Source
Old June 18th, 2013, 02:37 PM
Has anyone tried to fit a remote reservoir style Saginaw power steering pump to the Tdi bracket? It would appear that it needs only a redrilling for the Saginaw hole pattern to work. I might give it a whirl if it has been done. Saginaw pumps cheep cheep. I even have a couple brand new ones kicking around somewhere.
Old June 18th, 2013, 09:41 PM
It's more for the Mile Marker winchy.
Old September 9th, 2016, 08:15 PM
Naplm00
M
Anyone ever do this? Or even a regular Saginaw pump with the built-in res?
I hate my 200tdi pump
Old September 9th, 2016, 09:25 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
The 200TDI PS pumps are poor quality and suffer from premature failure.
I installed a Mercedes PS pump from an OM617 and it works flawless and even has a replacable filter.
Been in use since 2012 and still works fine during a daily drive scenario minimum 1 hour M-F.
RDavisinVA
Old September 10th, 2016, 05:17 AM
ezzzzzzz
Mark Garrenton
Be a pioneer and try to fab it up, Bill. The only real issue is pulley alignment. If it doesn't work nothing lost but a bit of time. You could just use the Mercedes pump with assistance from Robert Davis.
I need to go back to work for the break. Retirement is exhausting!
'71 IIA 88" LS1 hybrid
'84 110 5 door 'Nigerian Princess'
'90 RRC
'97 D1 LSE (parting out)
'02 D2 Kalahari
'02 D2 SE
'02 D2 SE
Old September 10th, 2016, 05:37 AM
Ha! Well time heals all and certainly this issue! No more 200tdi now.
300 uses much better pump. Should run the winch no prob.
Old September 10th, 2016, 05:52 AM
Chris B
72 + D1 drivetrain =?
Some discussion here: D-90 FAQ - Winch: Hydraulic Winches
At the risk of getting banned here, there is an article on dweb about fitting a ZF74 Pump in place of stock, to power both the winch and after adding a pressure relief valve your PAS system. https://discoweb.org/hydraulicpump.htm
remote, tdi
International HS2.8L Michael Defender Technical Discussions 448 April 21st, 2017 03:58 PM
200 Tdi Water pump BNIB o2batsea For Sale - Parts 7 June 5th, 2013 05:24 PM
Engine Swap: which one? 200tdi, 300tdi, or something I dont even know about gonzanc Defender Technical Discussions 46 April 2nd, 2013 08:36 PM
200 Tdi injection pump settings ... Retrofit Defender Technical Discussions 0 March 22nd, 2010 09:19 AM
200 Tdi injection pump removal ... Retrofit Defender Technical Discussions 3 October 28th, 2009 12:29 PM
