Relocating Warn 8274 solenoid pack? - Defender Source
Old February 25th, 2008, 05:39 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Since I have the winch off while the bumper is getting refinished I am changing the oil in my 8274 and thinking of moving the solenoid pack to under the fender. If I go get new cables made at the welding supply shop to reach from the solenoid pack to the motor would there be any issues in them being 3 feet long instead of the 6 inches they are now? I know the solenoid pack grounds through the bracket and thus motor so I would be sure to add a good ground to the new bracket.
Old February 25th, 2008, 05:42 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
I dont think you would have an issue.. I've seen plenty of people relocate their packs. I cant imagine the 8274 would be different??
Chris von C
[/size]
Old February 25th, 2008, 06:18 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I was thinking upgrading to one of those Albright waterproof solenoids might be nice too.
Old February 25th, 2008, 08:38 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I moved my solenoid to under the seat in the battery compartment. No issues. Just use the correct gauge cable. I think I used 2 gauge.
Semper Fi!
Old February 25th, 2008, 09:10 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Good idea, I have nothing in there now. Battery is still in the series position. Perhaps I could put it in the tool tray under the center console as alternatively. Then I could run the controller plug out the seatbox by the hand brake.
Old February 26th, 2008, 06:41 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Other than taking something simple and making it more complicated no worries moving it. I am alarmed however at some of the routing of power to winches that I see come into the shop as well as the wiring for the controls. Huge potential for shit going bad.
I've relocated the solenoids and controls on my own rigs as well as many customers, and at this point nothing makes me happier that to have all that stuff mounted (or as much as possible) OUTSIDE the truck.
Matt Browne
Old February 26th, 2008, 08:48 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
C'mon Matt, why simplify things?
Old February 26th, 2008, 11:23 AM
Cube II's Avatar
Cube II
Michele
1997 D90
8274 and Albright solenoids pack bolted to the wing lip inside and no troubles so far
(touch wood)
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old February 26th, 2008, 11:43 AM
Wolf Fabrication
Sterling Archer
'08 D3
My battery is already under my seat, so whether I wire power to the front bumper or wire the solinoid to under the seat, it's all the same thing. There were no extra wires. I see your point if the battery was located in the engine compartment and you wanted to put the solinoid in the cab. Wiring the solinoid into the cab also makes my winch more secure because there is no constant power to the winch out front. I knew a guy that had some vandals jump the power leads on his winch and did some serious damage when they ran the winch cable over the top of his rig to the back!
Semper Fi!
Old February 26th, 2008, 11:57 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
None whatsoever, technically, as long as you size them correctly. That said, if you aren't having problems, you may want to reconsider. The cost of copper has skyrocketed in the past year, about double what it was a year ago.
Ummm....3 wires (Field one, Field 2 and Armature) instead of one = extra wires.
A disconnect under the bonnet or in the cab would have prevented that. Doesn't really have anything to do with where the solenoids are located. You just want your disconnect in the feed line between your battery and the solenoid pack.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old February 26th, 2008, 12:04 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
The other reason I am doing it is to get the solenoid pack out of the way of intercooler airflow. Small difference but it all helps. I dropped the winch motor off at my local auto electric guy to recondition today as well.
Old February 26th, 2008, 01:01 PM
Wolf Fabrication
Sterling Archer
'08 D3
Tom: I have two wires going to my winch from my solenoid under my seat - power and a ground, same as if the winch solenoid was located on winch.
I think it's all opinion based on which is best of course. I had never remoted a solenoid to the cab on my previous vehicles, but it actually simplified my wiring.
Semper Fi!
Old February 27th, 2008, 06:39 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
Very valid point, and I wasn't inferring that moving solenoids around was a bad idea....just that doing it right is a good idea. You would be shocked to see some of the half ass things I see in the shop. I do like simplicity though.
Matt Browne
Old February 27th, 2008, 07:49 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Interesting, no idea what sort of winch motor would be wired like that. But Kevin's is a Warn 8274 so the motor takes 3 wires plus ground.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old February 27th, 2008, 11:35 AM
Wolf Fabrication
Sterling Archer
'08 D3
My guess is that is because mine is a permenent magnet type.
Semper Fi!
Old February 27th, 2008, 01:28 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Here you can see the intercooler setup with the temporary bumper while the Rockware is out for a hot dip.
Old February 27th, 2008, 02:33 PM
outfield
Steve
1995 D-90 SW #351
Hi Kevin,
It is common to mount the control pack under the "bonnet" in the UK and Australia. You will need to replace the 3 motor cables, use at least 2 gauge wires to prevent voltage loss. I mounted the control pack to the inner fender on the driver side, I used 1 gauge battery cables and 2 gauge motor cables.
With the control pack under the hood you will not have access to the remote control plug, so order a WARN part number 14867. This is a 2 foot long extension that will allow you to relocate the plug out side the engine compartment. I have mine mounted next to the driver side head light.
Steve
Old February 28th, 2008, 09:45 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Don't know the age of Kevin's winch (I think the newer ones have a different connector), but my 8274 controller connection is a very common 4 pin trailer socket. A lot cheaper than ordering anything from Warn
For what they charge for that kit, it would probably be cheaper to cut off the the one that's on the controller and convert it to something common.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old February 28th, 2008, 09:19 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
You nailed it Tom. Mine was made in 1978 and has the 4 pin socket, under 10 bucks at trailer supply places and I don't need to change my controller.
Old April 2nd, 2008, 08:42 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Got my bumper back on and the solenoid pack moved. I had new cables made at the welding supply shop and made a simple bracket to mount the pack using a bumper bolt so it is well grounded.
ID:	12863   Click image for larger version
ac
Warn 8274 question jaygoss Defender Technical Discussions 34 October 19th, 2010 03:46 PM
Rockware bumper Warn 8274 combo KevinNY For Sale - Parts 15 July 23rd, 2009 10:34 PM
Bumper for Warn 8274 winch? on a 90 Hammertime Defender Technical Discussions 7 April 1st, 2008 04:18 PM
Warn solenoid pack replacement Abrooks Misc. Chit-Chat 0 January 31st, 2008 03:13 PM
Need Warn Solenoid Pack tom155 Wanted 1 March 4th, 2007 05:45 PM
