Relocating Turn Signals - Defender Source
Old April 9th, 2004, 06:00 PM
Doug_Paoletti
Douglas P. Paoletti
'94 D90
Anybody know what wattage bulb to use when relocating the turn signals to the lower marker light on a 94 D90 to get the correct flash rate?
Old April 9th, 2004, 06:42 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Use an 1156 bulb. Thats what I have in mine.
Jimmy Buffett
Old April 9th, 2004, 07:09 PM
Doug_Paoletti
Douglas P. Paoletti
'94 D90
thanks
Old April 9th, 2004, 09:50 PM
flippedrover
Tyler
'94 D-90
Welcome
Jimmy Buffett
Old April 19th, 2004, 03:12 AM
scoloco's Avatar
scoloco
'94 D90 ST
1156 wont fit into the beehive lens on a 94. The wattage is right (it blinks at the correct rate), but the bulb itself is too big.
I looked in the charts and it says 7506 is the correct one, but they didnt have it in the store I was in.
Old April 19th, 2004, 10:35 PM
Doug_Paoletti
Douglas P. Paoletti
'94 D90
You're right Scott. I tried to install an 1156 yesterday and it is about a quarter of an inch too long for the lense cover.
Old April 19th, 2004, 11:29 PM
flippedrover
Tyler
'94 D-90
Hmm..I've got 1156 in mine with no problem. i don't think we replaced the bezel when it was switched.
Jimmy Buffett
Old April 21st, 2004, 02:30 AM
scoloco's Avatar
scoloco
'94 D90 ST
Douglas,
I did some digging and found out that a 105 bulb will work. Its small enough to fit and the resistance is enough that the lights blink about right. I got the lights rewired now and the blinkers now work good.
Hope you find this as useful.
-scott
Old April 21st, 2004, 09:16 PM
Doug_Paoletti
Douglas P. Paoletti
'94 D90
Thanks Scott. I'll give that a try.
Old April 24th, 2004, 08:23 PM
Doug_Paoletti
Douglas P. Paoletti
'94 D90
Thumbs up
The 105's did the trick.
Thanks again Scott.
Old July 25th, 2005, 02:34 PM
GliderKing's Avatar
GliderKing
Robert Bingham
97 ST D90
I just made this modification on my 110, and used the 105 bulbs on the front, but still have the fast interval. Any ideas?
everything else works great. At least it's flashing, I don't recommend driving around without front blinkers.... but it's a bit too fast for me.
Bob
Robert Bingham
1997 NAS 90 ST
1985 110 RHD 300tdi ROW
@gliderking instagram, twitter
Old July 25th, 2005, 11:23 PM
mattarm's Avatar
mattarm
Matt
1993 D110
http://www.defendersource.com/forum/...ht=turn+signal
Old July 26th, 2005, 11:43 AM
GliderKing's Avatar
GliderKing
Robert Bingham
97 ST D90
yup, read it, did it, and used the 105 bulb to change the amperage, but I still get the fast twitch turn signal. They all fire, both front and back, but at the fast rate. Any other ideas?
I don't need the parking light to come on as well, I'm happy with just the turn signal only.
Robert Bingham
1997 NAS 90 ST
Old July 26th, 2005, 11:49 AM
Just wondering what brand is the bulb? I have had the same problem with the dumb turn signals in the ARB I could put different bulbs in to get different flash rates. You may want to just try some different bulbes that fit to get the right rate, or you may have the wrong bulb in the rear turn signal. I would go to the parts store, and check their book to see what bulb is called out for the rear turn signal and check that against what you have.
signal
Turn signals don't work cdb Defender Technical Discussions 4 April 30th, 2009 11:10 PM
turn signals and flashers not working draaronr Defender Technical Discussions 4 April 27th, 2008 10:19 PM
Relocating bumper turn signals to the upper light housing paulb Smaller Projects 1 March 17th, 2007 10:50 AM
Flasher Unit LED turn signals rustydefender Defender Technical Discussions 2 November 14th, 2006 09:28 PM
