relocating the handbrake - Defender Source
Old June 5th, 2013, 09:37 PM
Cooperrat
2013 90
Exclamation relocating the handbrake
Hi All, having moved the handbrake on a 110 i owned to give me more legroom, i was wondering if anybody had relocated the handbrake on a new 90. I have previously moved the cubby towards the passenger seat and fitted the handbrake next to it. worked a treat.As my new 90 is yet to be delivered (its being built in UK. I live in australia)..its a question in advance...... cheers
Old June 6th, 2013, 09:52 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
On non-puma trucks it is easy to swap sides. You will have to source a LHD Hand brake if it is the same as older trucks. I do not know if the seatbox has the knock outs like the older trucks do.
Old June 7th, 2013, 03:36 AM
Cooperrat
2013 90
must admit,hadnt thought of the left hand drive "angle" on this one. thanks. will look into it in a bit more detail when it finally arrives in Oz...cheers
Old June 7th, 2013, 04:38 AM
I'm jealous that you can order a Defender. Jealous of that 2.2 diesel six speed stick etcetc..
Old June 7th, 2013, 03:49 PM
CamelTM's Avatar
CamelTM
Trevor
1998 Camel Trophy Defender 110 CT25
If you don't mind, could you provide a bit of info on where you moved your handbrake on the 110, and how you went about it? I have a 1998 110 and I am looking to do the same thing. It is a Camel vehicle so I want to be able to revert to the original setup, and minimize as much as possible the effects of the repositioning on the cab. So I'm on a bit of a scouting mission to see how folks have done theirs.
Old June 8th, 2013, 05:11 AM
Cooperrat
2013 90
Hi cameltm..I had sourced the instructions from a Landrober forum I think it had pics also ill try to find it again.. It moved the handbrake onto the area next to the drivers seat the cubby was moved towards the passenger seat to make space.. From memory no new parts were used..I just filled the holes with grommets.. Hope that helps
Old June 8th, 2013, 05:21 AM
Cooperrat
2013 90
Found it www.reedx.net Was a ranger over lever Good luck It was around 7,8 years ago when I did mine Memory fade !
Old June 8th, 2013, 08:45 AM
CamelTM's Avatar
CamelTM
Trevor
Thanks for that feedback, that helps a lot!
Old June 8th, 2013, 12:00 PM
I would not think it is that simple on the new trucks.... I think everyone is talking about the pre-Puma interiors.
Old June 8th, 2013, 05:47 PM
Cooperrat
2013 90
I did say that in my opening post First was a 2002 110 I did ask has anybody done a mod on a puma !,,,,
Old June 8th, 2013, 06:42 PM
OK, now I'm confused... I don't see any year reference in the first post. You did say "new 90", so I assumed you meant a completely new truck.
Is it a 2002 model OR is it a Puma? Pumas first came out in 2007.
Old June 8th, 2013, 10:44 PM
Cooperrat
2013 90
Smile
Ok. I had a 2002 110 I moved the handbrake on and I'm getting a new 90 and I shall want to move the handbrake on that. When it arrives from the uk.
Old June 9th, 2013, 09:47 AM
Right. This forum is mostly people from the USA and there are not many Pumas about. You would get a safer answer on the Australian forum. http://www.aulro.com/afvb/index.php
Old June 9th, 2013, 04:26 PM
Cooperrat
2013 90
yes i know ,tried that one but this site is a better and easier one to use.. thanks one and all.
NAS 110 Handbrake rogersta Defender Technical Discussions 3 November 18th, 2009 12:55 PM
handbrake cable fitting? Ren Ching Defender Technical Discussions 13 September 27th, 2009 05:55 PM
Relocating to the UK... madcowdungbeetle Misc. Chit-Chat 17 October 7th, 2008 05:07 PM
Relocating to the Boston area Chaucer Misc. Chit-Chat 9 January 7th, 2006 08:51 AM
Relocating Turn Signals Doug_Paoletti Defender Technical Discussions 13 July 26th, 2005 11:49 AM
