reliability of MSD multi-spark ignition and coils - Defender Source
Old April 7th, 2011, 11:19 PM
cdb
Clark Bowen
Ii bought a MSD 6A capacitive discharge ignition along with their coil, tach adapter for fuel injection and 8mm wires for my 1995 RRC with a soon to be installed 4.0 converted to distributor drive.
Rob a Southwest Rovers isn't crazy about non-stock items due to reliability issues.
I know that there were a number of conversions to MSD back in the early part of this decade and I wanted to find out how reliable they were and are you still using them.
Anyone.
2011 RR HSE -
2001 GMC 2500 4wd
Old April 10th, 2011, 12:02 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Never had much luck with any aftermarket can coil. The high-vibration models seem to last longer, but in the end you'll still want to carry a spare.
Now, my Mallory distributor and "E-Coil" open frame coil are still rockin after a few years.
-Hans
My oil line fix
My 100k stopped odometer fix
Old April 10th, 2011, 04:10 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
I went back to stock when I went through a couple of failures.
____________________
Chris Hinkle
Current project - D110 with extended cab and LS3
Old April 10th, 2011, 05:06 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
The high performance MSD models have been very reliable, I don't know about the street versions though. Some mfr's source out their entry/ lower level stuff and it's just not the same quality. I seem to remember that the MSD street multiple spark ignitions could be used with an oem EI and if it failed you could just disconnect it and run the oem unit. I don't know if that is still true or would apply to your install.
One trick with the MSD multiple spark ignitions is to make sure the distributor cap is vented. That may be a problem if your doing a lot of off roading.
Why did you decide against the oem electonic ignition?
Old April 11th, 2011, 11:09 PM
cdb
Clark Bowen
the OEM ignition works great but I wamted more juice amd flexibility with the MSD 6A Multi-Spark CDI, Blaster coil and the Boost Timing Master to retard the timing as the supercharger boost increases.
I've also added two wideband Air/Fuel Ratio meters, a vacuum/boost gauge and two Knocklites. It is beginning to look like an airplane cockpit. I don't have time to look where I'm going since I have some many gaues to watch.
2011 RR HSE -
2001 GMC 2500 4wd
Old April 12th, 2011, 08:29 AM
kevkon's Avatar
kevkon
kevin
Can't have enough gauges (Only problem in a Defender is where to put them all )
coil
Weird sparking around coils flynn23 Defender Technical Discussions 8 August 11th, 2008 11:13 AM
burning up coils tmore Defender Technical Discussions 2 July 23rd, 2005 07:43 PM
Performance Ignition Coil solihul Defender Technical Discussions 1 May 27th, 2005 04:28 AM
