releasing belt tension on '85 v8 fan belt - Defender Source
Old September 6th, 2013, 12:17 PM
Chris Velardi's Avatar
Chris Velardi
Chris Velardi
1975 101FC
anyone have insight into releasing tension on an early v8 fan belt tensioner ? I heave to replace the power steering belt but to get to it have to remove the fan belt (this is not a serpentine setup ) also have to figure out the power steering belt adjustment again it is on a 3.9 v8 1985
Chris "V"
Old September 6th, 2013, 12:57 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Hum.... Not sure what "early" means. On my '95 D90 (v-belt setup), I just undo the bolt of the tensioner if I remember correctly. I did this a few months ago and did not have any issue.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old September 6th, 2013, 05:33 PM
With a knife
Old September 7th, 2013, 01:10 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Just did this on the old man's 90. Pain in the ass. Loosen the belt tensioner. Then undo the bolts on the pulley wheel for the power steering (its the only way). Then cut the belt with a knife. Try and see if the belt will go on, if not then your going to have to rotate the pump till if fits. It can touch the bracket. Careful not to dent the pump with your dead blow hammer or you might even be able to use a large screw driver to lever it over.
As usual make sure to spray the bolts.
Old September 8th, 2013, 11:14 AM
Chris Velardi
Chris Velardi
1975 101FC
got it done , was thinking it was a spring loaded arm that I could unload the pressure on. what is the proper pulley on the face of alternator ? mine looks much narrower than power steering pulley it matches with (have eaten through two belts in two days (alternator is completely rebuilt and working smooth
Chris "V"
Old September 9th, 2013, 11:28 AM
MonLand
Loic Fabro
Mine has one less groove than the V8-4.0-serpentine setup on a disco (sorry... I made that comment yesterday as I reinstalled my alternator in the '95 D90 and the '96 Disco alternator was laying next to it). Definitely narrower than the flat power steering pulley. Are you going with cheap belts? Even those should last more than a day... I hope mine will last more than a day...
Now... I am realizing that we probably don't have the same setup as my alternator belt is ribbed, goes over/around the power steering pump flat pulley and onto the camshaft. I'm guessing your alternator in on the passenger/curb side and where my A/C compressor is? (That's where I have the not-spring-loaded tensioner).
You should count the number of groves on all the pulleys in the system.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old January 13th, 2014, 05:18 PM
CaptMidnite
Daniel Choi
94 NAS Defender 90 ST
Anyone have a link to a good write-up for removing and replacing both the fan belt and alternator belt on a NAS 3.9 1994 D90? Does the fan and shroud have to be removed?
fan, v8
Corect V belt tension 3.9 wantone Defender Technical Discussions 10 February 4th, 2013 11:23 PM
fan belt broke? tomaco1 Defender Technical Discussions 5 August 20th, 2010 08:45 PM
belt tension on a 95? durangorover Defender Technical Discussions 2 June 3rd, 2009 11:37 AM
Twin Electric fan kit for V8 D90 kiphartzell Wanted 2 March 17th, 2005 01:06 PM
