Relays - Defender Source
Old September 23rd, 2011, 12:44 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Relays
Interrogative: One of my relays is draining my battery. When I disconnect the battery there is a noticeable click of the relay working, so it's somehow constantly has power. Is it possible that the relay failed or should I search out a short? By the, I have no clue what the relay goes to and am still trying to isolate it (it's on my Series 1).
Semper Fi!
Old September 23rd, 2011, 01:00 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I'd pull the relay and test it. More than likely there's a short somewhere, but testing the relay is the first step.
While it's out you can see what doesn't work that it controls. Of course it's possible whatever it it was installed to control has been removed and you've no need for the relay.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old September 23rd, 2011, 01:11 PM
Wolf Fabrication
Sterling Archer
'08 D3
Relay is good. I traced it to a hack job interior light shorting somewhere. Damn Argeninians.
Semper Fi!
Old September 23rd, 2011, 02:13 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
Talking
Yeah right you probably wired that up.
Old September 23rd, 2011, 02:25 PM
Wolf Fabrication
Sterling Archer
'08 D3
Careful Dana, or I'll tell everyone that Jill helps dress you in the morning
Semper Fi!
Old September 23rd, 2011, 06:02 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
I think you have just done that.
Old September 23rd, 2011, 06:07 PM
Wolf Fabrication
Sterling Archer
'08 D3
Damn interweb!
Semper Fi!
relay
Silver Relay / Silver Relays rijosho Defender Technical Discussions 18 January 8th, 2012 01:07 PM
Electric Fan / Relays / Switch Override jijalicious Defender Technical Discussions 6 August 19th, 2011 02:33 PM
relays 300TDI Ray Bone Defender Technical Discussions 5 October 15th, 2008 12:46 PM
Turn signal relays JBfoot Defender Technical Discussions 4 March 5th, 2008 10:40 AM
Engine Dies: Fuel Pump & ECU Relays? jimngo Defender Technical Discussions 4 October 15th, 2006 01:25 PM
