Relay replacement help - Page 2 - Defender Source
Old April 17th, 2005, 09:39 PM
Thanks to several hours, yes hours of Mike's help on the phone, I managed to trace every significant wire in the ignition circuit. Yanked the dash and everything to get to the wiring.
The end result was that despite checking twice, I thought the main fuses were all fine (visual inspection) when in fact one had blown.
It probably blew as I had a loose connection at the starter...
Again, many,many,many thanks to Mike for his time and patience with me.
Sign me up for the Darwin award!
charles
P.S. Mike and I have decided that the D-90 source needs to add a private jet to next years budget. Mike could have flown down, and would have probably noticed the bad fuse right off the bat, smacked me on the head and then helped me with the original problem
Old April 18th, 2005, 07:42 AM
No problem Charles Glad to help, I have to make sure I can get as many Rovers to Rausch as I can, I may be needing rides around the park this time around.
ac, relay
Glow Plug Relay Michael Defender Technical Discussions 1 March 16th, 2006 02:28 PM
Hella relay Dfndr90 Defender Technical Discussions 3 January 30th, 2006 09:02 AM
Front Vent Seal Replacement Campbell Defender Technical Discussions 16 October 28th, 2004 09:11 PM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
Replacement Headlamps tuko Defender Technical Discussions 4 November 18th, 2003 09:51 PM
