Relay identifcation - Defender Source
Old June 6th, 2016, 08:37 PM
Ferniekids
Piers
1994 NAS 90 ST
Relay identifcation
After several hours of diagnosis of my 94 NAS D90 not starting I narrowed it to the fuel pump relay.
There are two silver relays under the passenger dash, (photo 1). I replaced the right hand one with a "used" 5 pin relay and it made no difference. I put the old left hand one on the right and the "used" one on the left" and it started perfectly (photo 2). Two questions: 1) what does the left relay do and 2) what does the right relay do. Just to be safe I will replace both, but just curious what I did and why did it work.
Also what is the relay on the far left and the green plug un the right?
Old June 6th, 2016, 09:14 PM
carlosz's Avatar
carlosz
Carlos
blue holder is the fuel pump, black holder is the ecu.
relay
Fuel pump relay 95 D90SW alaskajgg Defender Technical Discussions 32 September 18th, 2006 10:26 AM
Fuel Pump, Switch, Relay, or Wiring? bbandit Defender Technical Discussions 19 July 10th, 2005 12:08 PM
Relay replacement help cgalpin Defender Technical Discussions 21 April 18th, 2005 07:42 AM
LR Glow Plug relay temp? dmarchand Defender Technical Discussions 0 June 9th, 2004 01:42 PM
Electrical relay issues???? PMHAH Defender Technical Discussions 1 November 20th, 2003 02:32 PM
